Smoke From Woodburner Coming From Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 09:30 AM   #1
Smoke from Woodburner coming from Furnace
I had a fire burning in my woodburner yesterday and left the house for an hour or so, only to return to smoke eminating from my gas boiler, which has not been turned on for the season. They are flued separately but in the same brick chimmney and I have never had this problem before. Could it possibably have something to do with it has been cold 40 - 50 degrees and raining for days? I do not have a cap on the chimmney. I have cleaned the chimmney.
de616 is offline   Reply With Quote
Old 10-06-2010, 03:20 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
Yep. When it rains the barometric pressure changes and chimneys sometimes lose their draft or it changes. Possibly you had/have a negative pressure in the house and a slight downdraft in the boiler chimney which was cold and not drawing upwards as the boiler wuz off.. If the woodsmoke was not leaving its chimney fast enough it can get sucked back down the boiler chimney (in theory). Would only happen if it was very calm/not windy outside at the time.
The Following User Says Thank You to yuri For This Useful Post:
de616 (10-13-2010)
Old 10-06-2010, 06:00 PM   #3
Paul
Downdraft may be the cause, however it may be more serious; you may have a failure of the two liners and the flues are now connected inside the chimney. this is a very serious condition and you should have it checkout by a professional who can scope the flues.
Paul
www.finalsay.ca
finalsay.ca is offline   Reply With Quote
Old 10-13-2010, 08:12 AM   #4
We have had a half dozen fires since with no problem including that we opened the door that night and it corrected the problem. We are confident that it was a one time thing. Thank you!
Old 10-13-2010, 06:30 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 92
Get 2 new CO detectors one in the basement and one by your bedrooms. Any fossil fuel or Carbon based fuel, wood/coal/oil/nat gas can produce CO if not burning properly.
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Cigarette smoke coming through return? diyGK HVAC 5 10-29-2009 11:19 AM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
