Smoke Test - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 07:59 PM   #16
What are you trying to do?
If you have some ocd need to reinsulate chilled water pipe, come on down.
Master of Cold is offline   Reply With Quote
Old 09-20-2011, 08:01 PM   #17
An old Tradesmen
Rewards Points: 6,098
Originally Posted by JJboy View Post
http://www.grainger.com/Grainger/wwg...N=0&sst=subset
I think i found the fabric tape that I'm looking for.
Thats not fabric tape that your link takes me to, thats just pipe insulation tape.
Old 09-20-2011, 08:02 PM   #18
Hey!..I was trying to get some free labor here....
Old 09-20-2011, 08:08 PM   #19
An old Tradesmen
Originally Posted by master of cold View Post
hey!..i was trying to get some free labor here....
lol...
Old 09-20-2011, 08:17 PM   #20
JJboy's Avatar
So, Do you know the name or where I can get more info about the fabric tape in the picture?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-20-2011, 08:19 PM   #21
An old Tradesmen
I use mesh drywall tape.
Old 09-20-2011, 08:23 PM   #22
JJboy's Avatar
The image doesn't look paper tape.....looks like some kind of fabric.
Old 09-20-2011, 08:35 PM   #23
We seem to be having a mental block here.
I did not read, in the description of the link that you posted, that the tape was fabric.
The picture that you posted earlier was of fabric mesh tape, that had been painted with an elastomeric coating (mastic).
Old 09-20-2011, 08:45 PM   #24
JJboy's Avatar
I don't know what material is made this tape, but the texture seems to be a fabric.... so I'm asking because I know fiberglass grid or paper.
Doesn't look like fabric?
Old 09-20-2011, 08:57 PM   #25
The tape from grainger is foam tape. That stuff is a little nicer than truck stock.
That grey stuff is high velocity duct sealant, also known as mastic #9. Its made to seal metal ducts. The fabric tape is laid down on the material to help spread the mastic across the surface, and act as a firmament for the sealed joint.
Old 09-20-2011, 09:06 PM   #26
JJboy's Avatar
Where I can buy this fabric tape? Supply house doesn't have it. Any online place?
Old 09-20-2011, 09:11 PM   #27
Follow that enormous link..its at your home depot
Old 09-20-2011, 09:13 PM   #28
My wife says jo-ann fabrics has fabric tape..
Old 09-20-2011, 09:16 PM   #29
fabrk8r
fabrk8r's Avatar
We use Hardcast brand tape and mastic (two part sealing system) for underground duct.
http://www.hardcast.com/
For anything above ground we use regular duct sealant (ProSeal by DuctMate) applied with a 3" chip brush or fingers.
http://www.ductmate.com/product.aspx?id=23
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
JJboy (09-20-2011)
Old 09-20-2011, 09:17 PM   #30
JJboy's Avatar
Now I do not know if you're making fun of me.....I thought about that......but I also thought about something related to hvac LOL
Test your smoke DETECTORS! Leah Frances Safety 15 11-08-2012 08:05 AM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
