Old 09-20-2011, 01:52 AM   #1
JJboy's Avatar
Smoke Test
Where I can buy this smoke test?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-20-2011, 06:16 AM   #2
An old Tradesmen
Smoke Test
Make sure you are firmly in your hair before opening this link.
http://www.evhill.com/products/TT_Puffer.htm
Old 09-20-2011, 02:09 PM   #3
JJboy's Avatar
Smoke Test
I want to check inside of the return box....check in this video 9:00
http://www.youtube.com/watch?v=IV0Rw...eature=related
In this video they used fog machine...works perfect but only duct. Do you think the smoke can damage the coil if we use the fog machine with AC running?
http://www.youtube.com/watch?v=8rdA1...eature=related
Old 09-20-2011, 04:31 PM   #4
An old Tradesmen
Smoke Test
Fog machines put off a small amount of oil. So you don't want the A/C running, or it could be drawn onto the coil. Don't need the A/C running to use the fog machine. It will push its smoke through the whole system. just have to seal the registers as they show in the vid.
Old 09-20-2011, 04:41 PM   #5
JJboy's Avatar
Smoke Test
Ok, the problem will be isolate the coil from the plenum, that way the fog won't get in the coil. Thanks beenthere
Do you use mastic inside on the return box?
Old 09-20-2011, 04:45 PM   #6
An old Tradesmen
Smoke Test
Sometimes. If i can't get to the edges/seams from the outside.
Just connect the fog machine similar to what they did in the video, and you won't have to remove teh coil.
Old 09-20-2011, 06:32 PM   #7
JJboy's Avatar
Smoke Test
I can't find this fabric tape anywhere. Do you know the name? I see only the grid tape.
Old 09-20-2011, 06:42 PM   #8
Smoke Test
Its called fab tape.
There are two types sold. Adhesive for hvac and non adhesive for drywall
Master of Cold is offline   Reply With Quote
Old 09-20-2011, 06:49 PM   #9
JJboy's Avatar
Smoke Test
http://www.grainger.com/Grainger/OWE...FJ3?Pid=search
http://www.grainger.com/Grainger/OWE...&cm_vc=IDPRRZ1
for drywall is paper correct?
Old 09-20-2011, 06:52 PM   #10
Smoke Test
Nope..that's not it..
Old 09-20-2011, 06:56 PM   #11
JJboy's Avatar
Smoke Test
I can't find anywhere
Old 09-20-2011, 07:23 PM   #12
Smoke Test
http://www.homedepot.com/webapp/wcs/...ocStoreNum=159
Old 09-20-2011, 07:35 PM   #13
JJboy's Avatar
Smoke Test
I have that grid adhesive. I'm searching for what seems a cloth with mastic ( tape)
Old 09-20-2011, 07:43 PM   #14
Smoke Test
You put the mastic on the tape.
There is mastic tape, but it doesn't have the mesh, its backes with foil tape.
Old 09-20-2011, 07:56 PM   #15
JJboy's Avatar
Smoke Test
http://www.grainger.com/Grainger/wwg...N=0&sst=subset
I think i found the fabric tape that I'm looking for.
Test your smoke DETECTORS! Leah Frances Safety 15 11-08-2012 08:05 AM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
