Smallest Central Furnace Available? No Ac Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 03:36 PM   #1
Rewards Points: 191
smallest central furnace available? no ac needed
Hello and thanks.
Here is a quick scenario of what we are trying to accomplish.
The downstairs of our home consists of approx. 850 SF which is 2 bedrooms, a den, a bath and laundry.
I am looking to have a furnace installed in the 5 foot crawlspace below this area and have been told by multiple people that really anything we put in will be overkill for the area. That being said, we are not interested in electric, hydronic, baseboard, heat etc.
We also have no feasible way of running from the upstairs furnace and have decided on 2 seperate units.
Live in Newport Beach, CA where the winters are mid 40's on a bad day.
My question is what is the smallest sized central heat furnace on the market we should consider? Right now I think York has a 45k 2 ton, I am wondering if there might be something a bit less powerful.
Many of the manufacturers do not have all the specs on their website and point you to a local shop for answers.
Thanks for any ideas / suggestions.
beachfront71 is offline   Reply With Quote
Old 03-09-2011, 04:12 PM   #2
An old Tradesmen
Rewards Points: 8,154
York's smallest is 40,000 BTUs. I think Carrier has a 40,000 that is 2 stage. So that would be about 26 or 28,000 in first stage heat.
Old 03-09-2011, 05:11 PM   #3
Rewards Points: 191
Thanks.
If I go 2 stage, is there a way to eliminate the 2nd stage and just have it blowing on the lowest setting all the time.?
N
Old 03-09-2011, 05:14 PM   #4
Experienced
Jackofall1's Avatar
You don't need to eliminate the 2nd stage, the furnace should do it for you, if the demand is not there.
Mark
Old 03-09-2011, 09:54 PM   #5
An old Tradesmen
Originally Posted by beachfront71 View Post
Thanks.
N
Just don't connect the wire for second stage to the thermostat, but still and tell it that second stage is controlled by the thermostat. that way it will never get a call for second stage.
If you set it up to use the onboard timer, it could run long enough to time to second stage.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace is in attic, I want to move it because of efficiency issues... SimonSezz HVAC 1 01-22-2011 06:23 PM
Need help with OLD Central Furnace scarpen01 HVAC 1 01-11-2010 07:35 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
New Furance Pricing Feedback Needed s6skuzy01 HVAC 10 10-28-2008 10:43 PM
