Small Wood Stove - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2008, 09:11 AM   #16
Rewards Points: 163
Yes, it was all dirty. Not as dirty as inside the chimney, but still dirty enough.
And the opening above is square, and it has an orange flue through the whole chimney like this (though this is not my chimney, I just copied from the web):
dpreznik is online now   Reply With Quote
Old 09-03-2008, 09:21 AM   #17
the Musigician
DangerMouse's Avatar
ok, that would seem to me to be an old fireplace then, as most woodstoves have round pipe to mount up to the flue or out to the wall. looking at that pic again.... what is the 'mailbox' looking thing? it looks like a front porch... shoot a picture looking up the hole. might help too. (and that guy REALLY needs some chimney work done, huh? lol)
DM
Old 09-03-2008, 09:47 AM   #18
Rewards Points: 163
Don't pay attention at that thing. It is just a toy. There is a lot of junk around there. Unfortunately, I have no picture where I am now. It is just a square chimney opening in the ceiling with that orange flue inside.
Old 09-03-2008, 10:16 AM   #19
the Musigician
http://www.eurostove.co.uk/WESTFIRE-UNIQ-20_A47CM.aspx something like this might work, it's under 18" wide, soooo..... but it's in the UK too.
DM
Old 09-03-2008, 11:03 AM   #20
Not-So-Newbie
You might try a wall tent stove, or a military surplus tent stove.
Other than that, you may have to make one. There used to be kits for barrels years ago, & I have had a few but cant locate them anymore. Maybe try some of the big tool & Part catalogs (McMaster) & such?
Steven62 is offline   Reply With Quote
Old 10-23-2008, 06:15 AM   #21
Rewards Points: 163
Do you think the stove below would be a good thing to install?
http://store.colemans.com/cart/milit...l?currency=USD
Old 10-23-2008, 06:24 AM   #22
the Musigician
i suppose that would work.... the other one is prettier though.... lol
DM
Old 10-23-2008, 08:33 AM   #23
Rewards Points: 270
Try on www.hearth.com forums. They will give good suggestions.
pcampbell is offline   Reply With Quote
Old 11-04-2008, 09:26 AM   #24
Rewards Points: 163
Thanks everybody for suggestions.
Somebody gave me Jotul 602, though without legs. As I already mentioned above, I have for it a space on the picture below.
The width of the stove is not much smaller than the width of the opening above. Is it OK to put the stove into the space on the picture, so that the stove would heat the bricks around, and the bricks would radiate the heat into the room? Is it safe for the stove? Is it safe for the bricks?
Thanks in advance.
Old 11-04-2008, 09:59 AM   #25
the Musigician
great price on the stove! i think i'd look for a short leg kit online though, it'd look better. =o)
i see no reason why not to install it there, though an inspector will give you the answers, as a permit should be pulled for this install.
*good luck!*
DM
Old 11-12-2008, 06:18 PM   #26
Rewards Points: 163
Thank you for the answer.
Now I have another question concerning installation of the stove. I have chimney flue along the whole length of the brick chimney. Do I need to have a steel liner of the full length of the chimney? Are there any advantages and disadvantages of it?
Thanks.
Old 11-27-2008, 01:39 PM   #27
Did you ever find one? I have an antique stove in Georgia not in use.
jehiatt is offline   Reply With Quote
Old 11-28-2008, 07:54 AM   #28
Rewards Points: 163
As I wrote before, somebody had given me a stove, but I realized that it was missing burn plates. If you have one in Georgia, should I understand that you are giving it away? Is it small enough (because the space is limited)? And how would it get here? It must be very heavy...
Thanks.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 01:48 PM
