Small Tips For Basement Reno - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 09:42 PM   #1
Rewards Points: 160
Small Tips for Basement Reno
Just a few things:
1) Does it make any sense to move heat vents from the ceiling to the floor level?
2) I need to install a return in the basement - any tips on where I should put it, how big of a vent...basment is 25'x'50 and furnace is basically in the middle.
3) Anyone know basically what distance your floor vent on the 2nd level should be away from the wall?
Thanks again!
hellothere123 is offline   Reply With Quote
Old 02-17-2011, 02:30 AM   #2
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Originally Posted by hellothere123 View Post
Just a few things:
Thanks again!
1) Not really when you consider the amount of work, heat rises so low is good for heating but if you have to move a bunch of them I wouldn't bother.
2) You should have a return on every floor. I prefer to have a properly sized return in every large room and air pass-throughs in the smaller rooms.
3) I put mine about 2.5" from where the trim is (or will be)
unicursalhex is offline   Reply With Quote
The Following User Says Thank You to unicursalhex For This Useful Post:
hellothere123 (02-17-2011)
Old 02-17-2011, 05:52 AM   #3
An old Tradesmen
Rewards Points: 6,088
If they are rectangular or square registers. You can get registers that throw the air down for better heating. Its a lot cheaper and easier then moving supplies to the floor.
Return for the basement shouldn't be sized any bigger then the amount of air your putting in the basement. If its bigger, you run the risk of drawing in combusted fumes if your furnace is an 80%er, or if you have a gas or oil fired water heater.
I prefer to be 4 or 6" from the wall. Only because I hate to blow hot or cold air behind curtains/drapes when the register is near a window.
The Following User Says Thank You to beenthere For This Useful Post:
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 10:42 AM
Small room hardwwod refinish deejclow Flooring 1 04-29-2010 07:16 AM
I want to pour a small slab... Any pointers? Alan Building & Construction 2 04-17-2010 06:46 PM
Small, very small bathroom exhaust fan stubits HVAC 3 04-06-2010 02:52 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
