Small Gas Leak From Gas Regulator Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 08:16 PM   #1
Small gas leak from gas regulator vent
Hi, I have a small gas leak from my gas regulator feeding my heaters. The gas goes from holes on a vent bolt. You can see a bubble on an attached picture. The leak is slow - one bubble per 5 seconds. My question - is it normal, if not, what is a potential problem. And finally, should I replace the regulator, or my be I need just fix something (tight the vent bolt, for example). If a replacement is required, I'll call a plumbing company, but before that I want to understand the problem to avoid unreasonable charges.
Thank you.
azemerov is offline   Reply With Quote
Old 01-23-2011, 08:20 PM   #2
An old Tradesmen
Rewards Points: 6,846
Diaphram is probably cracked. Reg needs replaced, before it leaks worse.
Old 01-23-2011, 08:21 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,774
Usually that vent hole is to allow air in the chamber of the diaphragm so it can move up and down and regulate. If gas is coming out then the internal diaphragm has pinholes in it and the regulator is unsafe and needs replacing.
Old 01-24-2011, 07:40 AM   #4
WaldenL's Avatar
Rewards Points: 268
What they said. :-) But to add to it, bubbles are never "normal." Any bubbling at all is cause for concern, investigation and remediation.
WaldenL is offline   Reply With Quote
Small leak in low-slope roof Phillip99 Roofing/Siding 4 11-19-2010 05:30 PM
Stop leak product or homebrew for leaky drains? jack6128 Plumbing 4 09-12-2010 09:59 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 04:50 PM
AirConditioning Compressor - Oil Leak? MmagicBbusS Automotive Repairs 6 04-22-2009 09:02 AM
leakage on ceiling from bathroom above? milly tseng Plumbing 10 03-09-2009 07:53 PM
