Small Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 08:38 AM   #1
Rewards Points: 85
Small Furnace?
Hello,
I'm looking for a small furnace. It should be:
* 80% AFUE
* upflow
* 45K or 50K BTUH
* Low-Nox, California approved
* PSC motor ( my Fresno HVAC guy assures me that if an ECM motor or its driver board breaks, I will be VERY unhappy with the parts cost )
* two stage - for versatility
Right now, the closest I've found is the Goodman GMH80403AX. The only thing I don't like about it is that externally it looks like a one-stage. It just has a couple of dip switches to let you go low-heat for some minutes, then switch to high heat. I would REALLY rather have true two-stage control.
Anybody know of anything closer? Maybe in another brand? It seems there's not that many low-BTUH furnaces out there. Needing Lo-Nox narrows the field even further.
Thanks in advance,
- JerryK
jerryk1234 is offline   Reply With Quote
Old 09-25-2011, 09:32 AM   #2
An old Tradesmen
Rewards Points: 6,516
York, Lennox and others make them.
If your buying it over the internet, the you have no warranty. If you get it through a regular dealer, you can get a 10 yea parts warranty. VS ECM motors seldom fail. Just many don't know how to trouble shoot them, and condemn the motor, when there is nothing wrong with it.
Duct Work Too Small? Dakotamade HVAC 3 09-02-2011 01:34 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 10:17 PM
