Small Countertop Fridge - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 09:22 AM   #1
fastback4's Avatar
Rewards Points: 51
Small countertop fridge
My son has a small countertop bar style fridge that is trying to get cool but won't. We hear the pump working, the coils are warm and the bottom shelf is cool to touch. It's a Diamond Showcase Turbo Air fridge. Says it uses R-134 and has a high side pressure of 3. Can this be fixed with a shot of freon with sealer like we would repair a cars leak?.........Thanks Tom
fastback4 is offline   Reply With Quote
Old 07-25-2010, 10:04 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
No. You have to remove the freon, fix the leak and CAREFULLY measure/weigh in the amount in ounces of freon that it needs. Too much and it won't work properly or too little. Car sealer will plug the capillary tube and ruin everything.
Read this:refer. question
The Following User Says Thank You to yuri For This Useful Post:
fastback4 (07-25-2010)
Old 07-25-2010, 10:44 AM   #3
fastback4's Avatar
Rewards Points: 51
What can i expect to pay a technician to do this job correctly?.....Tom
Old 07-25-2010, 11:32 AM   #4
Hvac Pro
yuri's Avatar
I really don't know. If the leak is internal in the evap coil then the cost of repairs may be worth more than the unit itself. Lots of those leaks are in places where it cannot be welded etc. Probably look at a new one if it is worth less than $1000 IMO. At $75 or more an hour plus travelling it adds up in a hurry. I would get it assessed, may be a slowing moving fan or other problem. Are the door gaskets in good shape/door closes properly, not warped/not letting in excess heat and overloading it.
Old 07-25-2010, 03:05 PM   #5
fastback4's Avatar
Rewards Points: 51
Good suggestions. I'll look for other problems you mentioned. The unit is only 6 months old. My single 22 year old likes this fridge because of the see thru glass and it has small LED lights going up and down at the 4 corners ( ladies like that sort of thing ya know)....lol.......Tom
Fridge not cooling - evap fan? oppiecat Appliances 4 07-02-2013 04:19 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
Granite tile for countertop speedster1 Remodeling 18 12-16-2009 07:16 PM
Outdoor Fridge - Breaker problems Git Electrical 9 07-30-2008 05:21 AM
