Old 11-04-2009, 10:13 PM   #1
Default Small Ac Motor Wireing
I need help wireing this little electri motor. It has 3 wires, Blue/Red/Yellow. At the moment I have it wired up with only 2 wires. Red/Blue, It will run if I spin the shaft and get it started first. The motor came of of a Old Film Projector. I need this for a project. Here is a photo of the motor.
Also their was a double transformer in the box with it, and a small round filter/ I just have it straight wired at the moment.
Apreciate your help.
outback is offline   Reply With Quote
Old 11-04-2009, 11:08 PM   #2
nap
You talking to me?
nap's Avatar
the small round "filter". are you sure it is a filter and not a capacitor to start the motor?
it says right on the motor it needs a cap. the 10/7.5 mfd is the size required.
(the 10 is for 50 hz power and the 7.5 is for 60 hz power)
it also says it is reversible. I would think one of the lead you are using (I don't know which one offhand) and the one that is currently not being used would cause the motor to run in the opposite direction.
Old 11-04-2009, 11:29 PM   #3
Your probly right about the start cap, it must not be a filter. Heres a better picture of it. I tryed looking it up but could not find out for sure.
I should have payed more attention when takeing it apart, and made a wireing diagram, I just was in a hurry, and thought it would be simple. LOL
I'm thinking the power supply is not for the motor, but for the other electronics that was in it.
Now if this is a starter for the motor, maybe someone will know what wires to connect to it.
Thanks for your help.
Old 11-04-2009, 11:34 PM   #4
I just wired it up, as to what I thought maybe right? I'm not going to plug it in till I'm sure, I just did this as a potentioal example.
Old 11-05-2009, 01:56 AM   #5
Houston204's Avatar
Do you have an ohm meter?
Common to Run = a lower reading
Common to Start = a much higher reading
Start to Run = the sum of your other 2 readings.
The cap wires between Start and Run.
Power connects to Common and Run.
Houston204 is offline   Reply With Quote
Old 11-05-2009, 10:10 AM   #6
I have a craftsman multimeter.
That is pretty much Greek to me. I can just bairly understand it. Please explain it a little more detail. As this only has three wires. Do I need to used the motor as a ground when checking the wires?
O' yeah the motor had a Green chassis ground but I took it off.
Old 11-05-2009, 04:57 PM   #7
I figured it out, works great, now the motor starts up like it's supost to.. Thanks
Old 11-05-2009, 08:25 PM   #8
Houston204's Avatar
Yeah, I could improve my communication skills. I should have introduced my post more like...
These three wires are actually common, start, and run. There is a technique for determining which wire serves each function with an ohm meter.
Measure orange to blue, orange to yellow and blue to yellow and write down your readings.
The set with the lowest reading will include your common and run wires.
The set with the highest reading will include your start and run wires.
The remaining set will include common and start.
So, in other words...
The capacitor wires between Start and Run.
In my defense, it was 1:00 in the morning (local time) when I posted that.
I'm glad you figured it out
Old 11-05-2009, 11:16 PM   #9
Yoyizit's Avatar
Take readings everywhere so you know what's "normal" voltages, currents and resistances for this motor.
Yoyizit is online now   Reply With Quote
Old 11-06-2009, 11:15 AM   #10
I used Houston204 First directions, and just keept thinking about what he said, and used that to come up with the wireing. I have never ever wired an 3 Wire AC motor with a Cap Start before, it was pretty hard to understand. But now I know. Thanks Guys.
O' I was makeing a Coin Tumbler, thats what the motor is on. I also installed a Dimmer Switch in between the main power wires. Works great.
Old 11-06-2009, 05:04 PM   #11
An old Tradesmen
That is NOT a start cap.
It is a run cap.
A start cap needs to have a method of removing it from the circuit after the motor has started.
Old 11-06-2009, 07:25 PM   #12
O.K run cap... Yeah I had saw something mentioned about the Start cap, it's like a breaker, or selinod right?
Old 11-06-2009, 07:33 PM   #13
Yoyizit's Avatar
"Run capacitors are rated in a range of 3-70 microfarads (mfd)"
"Start capacitors have ratings above 70 microfarads"
Old 11-06-2009, 07:34 PM   #14
An old Tradesmen
No.
It is just a start cap. But, another device is also used to remove it from the circuit. So as not to burn up the motor, or start cap.
start caps are much higher micro farads then run caps.
More On This Topic
Freshwater perch are bony fish, typically with two separate or narrowly joined dorsal fins. There are roughly 150 different species of freshwater perch in the United States, Europe and Asia. One of the most common characteristics of perch is that they... Read More »
Hello! This is Peggy Charlton for Expert Village talking about how to write an essay. My next point will be concerning organizing the facts. Very, very important. You have gotten all your facts for your essay and they're in front of you. This is where... Read More »
How to Sign Colors
How to Sign Colors by Expert Village
Hello! My name is Melissa and on behalf of Expert Village, today we're going to be learning some basic signs, words, phrases in sign language. In our final clip, I thought we would learn a few colors, so we'll learn yellow, orange, blue, red, and green... Read More »
Hi, this is Sean Hobson, for Expert Village. What we want to talk about now is running the basic option play with the split backfield. Our fullback, this time, has moved off to the right side of our quarterback and our tailback to the other side. When... Read More »
Hi, this is Sean Hobson, for Expert Village. What we want to talk about now is when running the option play the quarterback is going to be one of our key focuses of the offense. If you have a fast enough and athletic enough quarterback you want this guy... Read More »
Soft floor in small bathroom/utility room TLLamb Flooring 1 04-28-2009 06:50 PM
Big HVAC Guy vs Small HVAC Guy flysndoc HVAC 4 09-20-2008 01:06 PM
Can a DIY build a small in-ground swimming pool? zel General Discussion 10 12-26-2007 07:41 PM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 12:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
