Old 12-23-2011, 01:48 AM   #1
slope for furnace intake pipe?
I am finishing a basement and the intake/exhaust pipes for my furnace hang down more than I want. The pipes are sloped and I'm guessing its to direct the condensation back toward the furnace to a drain pipe that is attached to the intake pipe. I would like to raise the pipe a bit to get them above a drop ceiling. My question is, how much slope do I really need? The span is about 15' and the pipe is hanging down roughly 4-5" from the joist at one end and tapers to touching the joist where it exits the wall.
ridgeway is offline   Reply With Quote
Old 12-23-2011, 05:27 AM   #2
An old Tradesmen
1/4" per foot. So 15/4=3.75 inches of slope, min.
Old 12-23-2011, 07:40 AM   #3
if you raise the pipe, make sure you raise the whole pipe not just one end....you may have to make a new exit hole.then apply what beenthere said at a min about 3.75 inches of fall toward furnace...
Driveway culvert to underground pipe zrooster99 Landscaping & Lawn Care 4 06-25-2011 01:42 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 1 07-12-2009 11:46 PM
