Slope Of Ac Drain And Condensing Furnace Drain. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 11:24 PM   #1
Rewards Points: 81
slope of ac drain and condensing furnace drain.
I installed two 3/4 inch drain lines for my new furnace and a/c coil that is installed in my attic. I need to see what everyone thinks about how I set it up. First of I came off the trap of the furnace and a/c coil with a good slope of about 1 inch per foot. The lines then went straight down for about 10 feet to the crawlspace of the house. From here I put an elbow on the two lines as tight and close as I could to the floor joists and then terminated the line out one of the foundation vent windows. My questions is the vent window is located at a height that it requires the line to have an upward slope of about an inch over about 7 feet. It is phsically impossible to have a downward slope unless I drilled two holes through the foundation lower than the windows which I don't wan't to do. Will the slope out of the furnace in the attic and the 10 foot drop be enought to keep me from having problems with this?
hartkem is offline   Reply With Quote
Old 11-24-2008, 01:08 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Where do you live?
If there is even a remote chance you will ever have freezing weather, I see this as a huge problem.
I wouldn't give drilling holes a second thought, I'd pull out the hilte and drill the holes.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-24-2008, 01:46 AM   #3
you could go uphill a couple of feet and it will still drain, the ten foot drop will provide enough gravity to drain it
kennzz05 is offline   Reply With Quote
Old 11-24-2008, 08:39 AM   #4
An old Tradesmen
Rewards Points: 6,086
Is there a chance the crawlspace can drop below 32.
If so. You got a big problem. It will freeze in the trap you created, and leave you without heat.
Old 11-24-2008, 08:49 AM   #5
Rewards Points: 81
I live in southern california and there is no chance it will ever freeze. I thought the 10 foot drop would allow it to work just fine. Just wanted to see what everyone else thought.
Old 11-24-2008, 09:38 AM   #6
An old Tradesmen
If the temp will never drop below 32, then it should work fine.
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Goodman Furnace does not kick in wctoro HVAC 2 02-20-2008 02:47 PM
