Slight Problem This Morning! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 12:11 AM   #1
Rewards Points: 150
Slight problem this morning!
8:00 am Christmas morning my Dad calls and his propane furnace and stove aren't working! I go over and he is at 45% in his tank,looking at the regulator mounted to the side of the house I noticed it was caked in ice from water dripping from the eaves and freezing on it. A bucket of lukewarm water and a slight tap (not sure if it helped but it made me feel better!) and everything was set to go. I believe the ice was frozen around the vent/breather on the bottom of the regulator. Do you think this was the problem rather than the ice on the rest of it?
Looks like I will have to fashion a hood/overhang to fit over it.
Thanks!
Gary
Gary_602z is offline   Reply With Quote
Old 12-26-2008, 05:49 AM   #2
An old Tradesmen
Rewards Points: 6,462
Probably was just clogging the vent.
Old 12-26-2008, 08:32 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Make that cover SOON! Clogging that vent can cause the regulator to develop excess pressure and overfire the furnace and has caused explosions on natural gas systems. The excess pressure can blow the gas valve.
Old 12-26-2008, 12:07 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Around here, there are about 2 or 3 house fires/explosions each year caused by an ice covered regulator. It's far more hazardous than you might think.
Rob
micromind is offline   Reply With Quote
Old 12-26-2008, 12:47 PM   #5
Hvac Pro
yuri's Avatar
City gas main pressure can go up to 60 psi. Gas valve rated for 1/2psi. House go BOOM BOOM. Gas co. guy told me of such a story where I am. Scary stuff!!
Old 12-26-2008, 10:27 PM   #6
Rewards Points: 150
Got my buddy making a cover! On the LP tank there is one regulator and then another at the entrance to the house. Are they just set at different psi?
Gary
Old 12-27-2008, 06:04 AM   #7
An old Tradesmen
The primary, brings the pressure down to 10 PSIG.
The secondary/house regulator lowers the 10 PSIG to 11.5" or so.
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
squeeze & learn..slight problem Lin Electrical 1 02-06-2004 07:46 PM
