Sleeve Ac Barley Blowing Air - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2014, 01:59 PM   #1
bryanp22's Avatar
Rewards Points: 294
Sleeve ac barley blowing air
Hi,
We have a sleeve ac unit in a condo we rent out and it seems to barely blow air. Is that something we could maybe buy a new fan motor for or is it best to replace the unit?
bryanp22 is offline   Reply With Quote
Old 07-27-2014, 02:11 PM   #2
Rewards Points: 6,652
Nope. You need a new unit. Which will mean that the new one will not fit into the old wall sleeve. Talk to your Condo board and building maintenance if there is a particular model that can fit the sleeve you have currently.
Old 07-27-2014, 05:45 PM   #3
An old Tradesmen
Rewards Points: 7,760
It may be just a bad capacitor, causing the fan to spin too slow. Check it before buying a new PTAC when you may not need a new one.
PTACs come in many different physical sizes.
Old 07-27-2014, 06:21 PM   #4
Rewards Points: 13,960
Is the fan running slow or is it just not blowing out enough air?
Checked the air filter and fins to see if there clean?
Old 07-27-2014, 08:58 PM   #5
bryanp22's Avatar
Rewards Points: 294
I took the cover off and the blower grill was almost completely blocked. Cleaning that did help but it still seems to blow pretty weak. The prior tenant didn't complain but I just don't remember how it worked two years ago.
How could I check bad capacitor?
Old 07-28-2014, 03:49 AM   #6
An old Tradesmen
You would need a multimeter that check read/check uF. If you don't have one available, you cna simply try putting in a new one. take the old one to Grainger, and get one that matches it.
There is also a good chance that the coil is dirtier then you think. Spray it with Simple green, let it soak for a while, and then rinse it off. Or just run it.
PTACs often don't blow real hard.
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 03:03 AM
First Time Homebuyer- Heil DC80 blowing cold air chwkrx7 HVAC 20 11-07-2012 07:41 AM
Replacing Lead Sleeve Soil Stack alllthumbs Plumbing 3 12-13-2011 08:34 AM
install 4x4 post with vinyl sleeve to exisiting slab and top header Rusty Johnson Building & Construction 1 08-20-2010 05:50 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
