-   -   Sleek/Slim Look AC (http://www.diychatroom.com/f17/sleek-slim-look-ac-173694/)
Mstrlucky74 03-05-2013 08:48 PM
Sleek/Slim Look AC
265 Attachment(s)
We currently have a pretty big in wall ac in our living room. Are there any "slim/low profile" type in wall ac's out there? It looks like there are only ductless ones that are very expensive. Thanks.
old_squid 03-05-2013 08:57 PM
You might be able to find a bit smaller through the wall unit of the same size (capacity), but it's going to take X amount of bulk to do the work. The mini-splits divide that bulk between two units.
Mstrlucky74 03-06-2013 04:40 AM
265 Attachment(s)
Thanks ...my AC unit now is about 15,000 BTU and all the splits seem to be about $1,000+...
beenthere 03-06-2013 05:13 AM
If they made smaller sized 15,000 BTU thru the wall units, they would probably cost about the same as a ductless.
joecaption 03-06-2013 06:18 AM
A mini split may seem expencive but will be far quieter, use a lot less electricty.
LG sells a model that only needs a thin face plate that you can hang a picture on.
I opted for one that heats and cools for a 800 sq. ft. rental I own.
I used to heat with gas and was paying over $50.00 a week for fuel.
Now my total power bill for the whole house is $50.00 a month
Now I only use the gas for cooking and have not had to buy gas for 3 years.
I was amazed at how small a wire was needed to power it, even standing next to the unit outside it's hard to hear it running.
If I remember right it was only a 12-2 wire with a double 20 amp. breaker.
It only needed a small whole in the wall, 3" I believe.
I installed the whole thing myself except making the line set connection.
Mstrlucky74 03-06-2013 07:46 AM
265 Attachment(s)
Sweet, nice Joe. Dumb question:laughing:. Split ac unit do both heat and ac? Why would I need it to heat...have baseboards
joecaption 03-06-2013 08:07 AM
You can buy them that just have A/C or both heat and cool. At the rising price of oil and as a back up if that boiler goes down it may be worth the extra money to to go with the heat and cool.
Hard to say how well it would work in your area since you still have not added your location to your profile.
Mstrlucky74 03-06-2013 09:14 AM
265 Attachment(s)
lol..NY . Thanks. I will update
Mstrlucky74 03-06-2013 09:17 AM
265 Attachment(s)
What model #?
Mstrlucky74 03-06-2013 09:30 AM
265 Attachment(s)
I see some of these brands that I have never heard of. Has anyone heard of these?
http://www.ac-world.com/MiniSplitAir.php
joecaption 03-06-2013 09:42 AM
Never heard of them before.
This is the brand I have.
http://www.mitsubishielectric.com/bu...s/s_range.html
I'm no HVAC guy but you may live to far north for a heat pump to work correctly because of the cold. It would work just cost more to run because the back up heat strip would have to kick in to keep up.
I'm sure later in the day some will be online.
Mstrlucky74 03-06-2013 03:10 PM
265 Attachment(s)
Is installing a split system(cooling only) a DIY project?
beenthere 03-06-2013 03:59 PM
I get the heat pump. can save you some money on your heating bill.
Mstrlucky74 03-07-2013 06:14 AM
265 Attachment(s)
Not sure then what Joe meant when he said the heat pump might not work correctly. Thanks.
If others could chime in that would be helpful.....should I get a heat pump? Thanks.
JScotty 03-07-2013 12:32 PM
Heat pumps are A/C's that work in reverse. Instead of moving heat from your house to outside they reverse the freon flow & move heat from outside to inside. Freon at atmospheric pressure is well below 0 degrees ferenheit so the freon can be pulled down to temps lower than outside air & still pull heat from the cold air outside. And it's significantly cheaper than gas or electric heat.
The issue with this is as the air gets ciolder it's harder for your unit to make heat from. Once it drops below 20-30 degrees outside the unit won't be able to make enough heat to heat the space. At that point the electric resistance heat has to kick on to keep up.
So basically depending on how cold it gets in the winter, the heat pump might not do much for a lot of the winter. But if you don't get below 20 degrees very often it can save you quite a bit.
For instance I recently bought a house that had radiant ceiling heat (similar to your baseboard heaters) and an A/C only system that was about 3 years old. I removed the new A/C and replaced it with a heat pump. Granted I can do the work myself & even get the units at a discounted rate since I work for an HVAC company, so it was a little cheaper for me to do that. But if you're going to put in a new A/C anyway the difference between putting in a heat pump shouldn't be much more expensive.
