Sizing Of Ventilation Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 01:55 AM   #1
Rewards Points: 528
I have 21 feet of duct to install to vent my basement bathroom to the outside. This includes 4 elbows and maybe a reducer depending on whether I use 6 inch or 4 inch duct. The fan specifications are:
1/20 hp 1.95 amps 270 cfm at free air and 250 cfm at 0.05 static presure and on down to 70 cfm at 0.375 static pressure.
The bathroom has 556 cubic feet area. The blower and fan are mounted into a steel box that has a discharge flange opening of 3.25 inches by 10 inches. I think this indicates I should use 6 inch duct but I need confirmation. But if I go with 6 inch, I will need to reduce it to 4 inch to accomodate the 4 inch opening in the foundation wall.
So which size should I install? Is 19 feet of 6 inch duct reduced to 4 inch at the last two feet better then installing 4 inch for the whole run?
rjordan392 is offline   Reply With Quote
Old 05-18-2009, 05:27 AM   #2
An old Tradesmen
Rewards Points: 6,480
Use 6".
Old 05-18-2009, 08:18 AM   #3
Rewards Points: 528
Thanks, 6 inches it will be.
Old 05-18-2009, 09:06 AM   #4
Fart Fan?
hvaclover is offline   Reply With Quote
Duct sizing C44 HVAC 3 03-23-2009 05:24 PM
Need help Duct Sizing. Cyon HVAC 2 07-23-2008 09:15 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
duct sizing Stu HVAC 2 12-22-2006 06:36 PM
Duct sizing question Rob HVAC 1 06-04-2005 01:42 PM
