Sizing Radiant Heat Circulators - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 06:18 PM   #1
Question
Sizing radiant heat circulators
Hi Guys, Just put up 650 sq. ft. 2 story addition on my old house. Add. is radiant, all calculated from watts radiant pro. Not sure what pumps to use ( 2 zones). upstairs is 2-160' loops 1/2" pex with 3/4" S&R about 50' long. Downstairs 2-300' 1/2" loops, 3/4" S&R. Manifolds are in room with adjustable flow control. 2nd flr looks like .4 gpm and .5 head . Not sure about 1st flr, comp crashed and i lost info. I was thinking taco 00RIFC's set on low. What do you think, Thanks!
Nverdone is offline   Reply With Quote
Old 10-28-2010, 08:23 PM   #2
An old Tradesmen
Rewards Points: 6,142
I think your forgetting to add in all your other pressure drops.
What water temp are you planning on using. As this effects head pressure in the pex.
Old 10-29-2010, 10:23 PM   #3
Watts radiant program comes up with 108 degree water for 1st floor (slab) and 93 degree water for 2nd floor.
Old 10-30-2010, 12:11 AM   #4
Home Air Direct's Avatar
The Taco 00RIFC is more then enough pump for your loops. We are selling them 2-1 over the old standby of B&G100s. They are lasting longer with significantly less warranty issues.
Good luck.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 10-30-2010, 04:46 AM   #5
An old Tradesmen
Good luck.
Haven't sold a B&G 100 series in many years. Unless it was speced in the bid request.
So what is the GPM at 10 foot of head for a 00RIFC
Old 10-30-2010, 11:19 AM   #6
Looks like 1.5 - 2.5 depending on speed.
Old 10-30-2010, 04:26 PM   #7
An old Tradesmen
He needs to get it(GPM) down, for his shorter loops. The longer ones will probably be ok.
Old 10-30-2010, 06:59 PM   #8
my manifolds have flow meters and balancing valves so i can set the required flow. should i look for smaller pumps. thanks
Old 10-31-2010, 03:33 AM   #9
An old Tradesmen
As long as the 00RIFC are 3 speed. And you can use their lower speeds and not have to choke back the balancing valves too much. They are good to use.
I prefer to use the smallest possible circs. And one that are readily available at local supply houses.
The Following User Says Thank You to beenthere For This Useful Post:
Nverdone (10-31-2010)
Old 10-31-2010, 03:35 PM   #10
I'll probably go with the 3 speed taco 00r so i can fine tune it. Thanks everyone.
Laminate Floors over radiant heat in concrete slab richnsht Flooring 8 05-23-2009 01:16 PM
Insulate joist bays along with radiant heat, how ? iMisspell Building & Construction 2 12-08-2008 01:17 PM
Radiant heat question tpagel HVAC 4 05-21-2008 05:57 PM
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 09:58 AM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
