Old 08-21-2011, 07:53 PM   #46
An old Tradesmen
sizing choice on system upgrade
Look at your old furnaces CFM rating at statics/ESPs above .5".
Again, improve the homes insulation and seal it better. this will save you money in both heating and cooling season every year, year after year. A larger furnace just uses more fuel, and cost you more money year after year.
Old 08-21-2011, 08:07 PM   #47
raylo32's Avatar
The Bryant manual only has the single topline numbers for "certified conditions" between .15 and .5 so no way for me to check that. I might try to borrow a manometer and see what my actuals are. That would be interesting.
Not much to seal here. House is pretty modern. I guess I could put a storm door on the windward exterior door. Almost impossible to do anything in the attic with cathedral ceilings. Only an 8x8 area is accessible. Not sure what R-value the flex ducts up there are but replacing them would cost way more than any savings.
raylo32 is offline   Reply With Quote
Old 08-21-2011, 08:12 PM   #48
An old Tradesmen
Any switches or receps on outside walls? Also the ones on inside walls sometimes leak a lot also, if the holes in the plates at the attic and basement/crawlspace aren't sealed.If so, seal them. How about worn door seals?
Old 08-21-2011, 08:17 PM   #49
raylo32's Avatar
Yup, door seals could use replaced. Or just add a storm door on the windward door that is the main front entrance. The south side leeward doors (2) aren't so critical. The attic is impossible. I have cathedral ceilings so no way to get anywhere but an 8'x8' "attic" in the center of the house. Otherwise need a spry midget with a light and dust mask to try to crawl in the rafters up to the wall plates..... or rip out ceiling drywall. Not gonna happen!
Old 08-21-2011, 08:23 PM   #50
An old Tradesmen
Any sealing you can do, will help greatly. Also helps keep the indoor humidity up in the winter.
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
New HVAC System Recommendations shwank HVAC 14 10-12-2010 03:15 AM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
