Size Of Unit Per Sq Ft - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 11:16 PM   #1
size of unit per sq ft
If i have a 4 level home basement first and second floor and attic, if the first and second floor is about 4700 sq ft in a brick home built in early 1900's what size central unit do i need?
ddavis14 is offline   Reply With Quote
Old 07-17-2012, 11:26 PM   #2
Rewards Points: 13,270
That's not how it's sized, better start making some calls to some pro for help on this one.
Old 07-17-2012, 11:39 PM   #3
Missouri Bound's Avatar
A lot of research has been done in determining the proper size HVAC equipment. It's available here.......ACME.
Do you want it your way or the right way?
Old 07-18-2012, 04:32 AM   #4
The standard rule of thumb is 600 sqft per ton, but as others have said you should really, really get a load calculation done on a house like that. So many factors come into play - insulation level, type of construction, window/door type and condition - that you really cannot SWAG something like this.
scottmcd9999 is offline   Reply With Quote
Old 07-18-2012, 06:04 AM   #5
An old Tradesmen
Rewards Points: 6,480
You can use HVAC CALC and find out what size so you don't end up having to come back and ask what to do about high humidity, or not getting cool enough questions.
In Arizona 600 sq ft per ton on an old house with little to know envelope improvements would give you problems getting down to 86 on a hot day. In Washington state, it would give you high humidity problems.
HVAC CALC has a 50 dollar license fee to get the load results. It can save you more then that in just aggravation, let alone unit and duct problems.
Drain line plugged on air handler unit - need advice spta97 HVAC 19 07-26-2011 08:50 PM
Old carrier unit trouble hdbg62 HVAC 18 06-29-2011 09:57 PM
Physical size of Central AC unit Marjorie HVAC 2 06-20-2010 07:43 AM
Need help determining the size of an upstairs HVAC unit BigE516 HVAC 11 03-17-2009 04:25 PM
wire size for ac/heating forced air unit macfluke Electrical 2 03-04-2009 01:29 AM
