Which Size Propane Tank For Fireplace? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 12:12 PM   #1
Rewards Points: 83
Which size propane tank for fireplace?
Hi,
First timer here. We are in a new home that is powered by electricity, including cooking, heat pump, water tank, heat, etc. The only thing which requires gas is our fireplace. Had I realized that beforehand we probably would have ditched gas altogether and went with wood burning fireplace, but alas, hindsight :-). Anyway, many of our neighbors have 200 gal propane tanks that fuel their homes, as there are no gas lines in this area. However, they may have more appliances tied into their propane, whereas we just have the fireplace. So here is my question: for our situation, would it be better to get one of the 200 gal tanks, or is it possible to even go with a standard grill-sized propane tank? We have A grill sized one hooked up now as a temporary solution. I kind of like the idea of the control that comes with a small tank that I can take to refill. But, I wonder if there are any safety, monetary, or other advantages of having the big 200 gal drum vs the small portable tank, or vice versa? Any input would be greatly appreciated, as I am new to the use of propane and homeownership in general :-). Thanks !
darthsmozers is offline   Reply With Quote
Old 12-31-2011, 12:20 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome darthsmozers, to the best darn DIY'r site on the web.
The size of tank needed is directly proportional to the amount of use. As a gas fire place is generally for show and adds little to heat in the dwelling, I would tend to say stick with the smaller tank.
Mark
Old 12-31-2011, 12:21 PM   #3
MarginallyQualified
Rewards Points: 2,464
Depends on how much you'll be using it...
and how much trouble you're willing to put up with to replenish when empty.
Works for me.
Ride it out for a season (or two). See for yourselves.
Or... try to sell it and get the woodstove you would prefer!
Nah. Mostly just the PITA aspect.
hth
Old 12-31-2011, 01:08 PM   #4
Rewards Points: 83
Mark
Ah good call, I should have mentioned the usage. Likely at the most one evening each weekend in winter as we aren't home enough during the week to really enjoy it. And at most for an hour each time.
And thanks for the welcome!
Old 12-31-2011, 01:10 PM   #5
Rewards Points: 83
Works for me.
hth
Hmm, trying the small for a season or two to see how much we use it is a great suggestion. And at the worst if we decide to upgrade later we could keep the small tank for other uses like grilling! Good suggestion, thanks!
Usage would likely be on weekend, maybe an hour at the most once a week.
Old 12-31-2011, 01:14 PM   #6
Rewards Points: 14,290
If you go with to big a tank and do not use at least a certin amount per year your stuck with having to pay rental for the tank.
I went from gas heat to a mini split and only use gas for my cooking stove.
It's been a year and I've only used about 10 gal. and have not had to call for a delivery so now they want me to pay $120.00 just for having the tank.
Old 12-31-2011, 05:08 PM   #7
Rewards Points: 83
Oh good point. Is it possible then to buy the tank outright or is that very expensive?
Old 12-31-2011, 05:11 PM   #8
HVAC Tech/ Browns Fan
I did seen other day someone is selling 100 gal tanks. May need call around and ask about it. I also did hear people with small gas grill tanks hooking them up to the house fire place and when kids are playing around them knocking them over and snapping the flex gas line. If you have kids need think about that
Tator1076 is offline   Reply With Quote
Old 12-31-2011, 05:12 PM   #9
Rewards Points: 1,216
Most gas fireplaces come with instructions as to the size tank to be used.
Many require a 100 LB tank.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
ben's plumbing (12-31-2011)
Old 12-31-2011, 06:09 PM   #10
Lowes and HD both sell 100 gal. tanks but check if your local gas companys will fill them. May be cheaper to just have them deliver one and use there's.
Old 12-31-2011, 06:18 PM   #11
Rewards Points: 350
Up here in NH, many gas companies will install a tank and keep it filled for you. the problem is that the price is based on usage, the more you use, the lower the price. We have a small tank for our gas range, they just put in 5 gals, at $4.69 a gal. yikes. If you use, say, 1,000 gals a year, the price is about $2.95 a gal. As for the fireplace, I *think* (don't take my word on this) that you can get fireplace inserts that throw some very good heat as well as produce a nice show.
dougp23 is offline   Reply With Quote
Old 12-31-2011, 11:18 PM   #12
Rewards Points: 6,652
A 200 gal. tank is not that big. Are you sure that they are not larger tanks? A 200 gal tank is just a larger sized 20 gal that you see on propane gas grills.
Old 01-01-2012, 10:07 AM   #13
Rewards Points: 760
One thing to consider, anything over 125 gallons has to be at least 10' from the house.
AandPDan is online now   Reply With Quote
Old 01-01-2012, 10:39 AM   #14
Hi,
For the most part you have been given great advise, one thing to keep in mind is that local building code have very strict rules regarding the placement and usage of propane cylinders and tanks, so before making your final decision, I would check with your local building inspector and or the propane supplier them selfs. They should be up on all local codes.
harleyrider is offline   Reply With Quote
Old 01-01-2012, 11:34 AM   #15
Rewards Points: 83
Thanks for all the advice. Looks fairly split between small and large. I suppose my best bet is to call America's and just see about the small one first, to see if it's acceptable for now. Maybe we will try it for a winter or two and then decide on a larger one? Good ,points from you all though, from kids to distance to cost, and I appreciate all the insight.
Thanks!
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
propane tank size for water heater aladerach Appliances 2 10-02-2011 08:36 PM
Aerator pump size for septic tank spaceman spif Plumbing 9 03-17-2011 11:40 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
