Size Of Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2015, 07:44 AM   #1
Rewards Points: 27
Size of Heat Pump
I live in Florida and need to purchase a new heat pump -- total package with air handler. My home is one level with 2500 square feet. What size should I purchase -- is 5 ton the size.
Secondly, are most heat pumps manufactured in China. If so does it really make any difference which name you purchase.
Thanks so much for taking time to respond.
repairlady is offline   Reply With Quote
Old 09-21-2015, 08:20 PM   #2
Rewards Points: 3,952
A load calc is the only true way to size equipment, especially in a humid place like Florida.
You can try your own here.
www.loadcalc.net
roughneck is online now   Reply With Quote
Old 09-22-2015, 08:24 AM   #3
Rewards Points: 112
What size is in there now? Not saying it is the correct one, but how did it cool you in the extreme Florida summers? Perfect/just OK/Poorly? any hot or cold spots in the house? Did it struggle during the summer?
The correct way is to have a manual j done on your home. You will be told here and it is true, that if you oversize, the ac will not remove the humidity correctly.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Breakers, wire size and new heat pump ACR_SCOUT Electrical 21 01-29-2012 02:25 PM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 09:14 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 09:22 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
