Size Of Air Condtioner Req'd - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 06:06 PM   #1
size of air condtioner req'd
I live in an 850 sq ft apartment and would like install a split unit air conditioner. I have a southern exposure, lots of windows and glass sliding panels that allow lots of light and heat in. I have several quotes of $3,000.-$10,000. to install. Every quote tells me I need a different size of air con. Has anyone got any ideas of what size split air con unit I need? Thanks
rickhorner is offline   Reply With Quote
Old 06-27-2010, 06:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 384
Try this heat load calculator:Load Calculator
Old 06-27-2010, 07:15 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
unless you own the apartment or the LL agrees to you installing the AC, you do not want to deal with a split unit.
Old 06-27-2010, 10:38 PM   #4
Use the link yuri posted to be sure. For 850 square foot a ton and a half should be more then enough unless you live where it's over 100 most of the summer or like the cooling set on 68.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Room size X floor tile size deck hand Flooring 4 04-08-2009 04:42 PM
duct work size justmefixin HVAC 2 09-20-2008 06:59 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
