Sit Boo Boo, Sit! - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 07:45 PM   #1
I'm Your Huckleberry
Rewards Points: 2,270
Sit Boo Boo, Sit!
Bad dog!
Doc Holliday is offline   Reply With Quote
Old 08-21-2011, 10:00 AM   #2
Rewards Points: 85
An example of Best Practices for my new HVAC install?
jerryk1234 is offline   Reply With Quote
Old 08-21-2011, 10:21 AM   #3
An old Tradesmen
Rewards Points: 6,112
You can use clear vinyl hose to sleeve the thermostat wire, and wire tie it to either the liquid or vapor line to protect it from animals, including people with weed whackers.
Old 08-21-2011, 12:28 PM   #4
I suggested she just have a small fence built, about 5' wide from the side of the home to the fence line, to keep that area seperated from the dog.
Old 08-21-2011, 01:18 PM   #5
An old Tradesmen
But will she?
Old 08-21-2011, 05:38 PM   #6
But will she?
Probabaly not. Her thought was to chain up the dog. We've had a record 20 days of over 100 degree temps here and as it is the dog is in the back yard all alone and so my first thought was chaining her up would be cruel so instead just put up a barrier.
Old 08-21-2011, 09:55 PM   #7
Rewards Points: 6,652
Hopefully has not been using the unit to do his business on, thinking that it needs watered. Some Green garden barrier fence would be easier, than a permanent fence. Even something like a kennel that is one of those that are panels, would even be better.
Old 08-21-2011, 10:09 PM   #8
I've seen that before, the urine just eats away the coil but this is a female dog so no dirty business on the condenser. She's really sweet, just needs more attention and chew toys, me thinks.
Old 08-21-2011, 10:11 PM   #9
Deer Antlers Doc. Our Golden loves them.
Old 08-22-2011, 05:47 PM   #10
Hey Doc..where's yer low loss fitting fer yer hose on that hi-side hose?
hvaclover is offline   Reply With Quote
Old 08-22-2011, 07:22 PM   #11
JJboy's Avatar
I see hvaclover is back.....i'm glad
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-22-2011, 07:32 PM   #12
Low loss=vacuum leak.
Master of Cold is offline   Reply With Quote
Old 08-22-2011, 08:31 PM   #13
JJboy's Avatar
This is a serious statement
Old 08-22-2011, 09:18 PM   #14
I quit using all that fancy low loss stuff. I have hoses with ball valves in them. Just remove the hose off the liquid line the old way..push the hose into the fitting and unscrew.
