Single Return Box Goes To Two Rooms, No Privacy - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 09:35 AM   #16
Rewards Points: 314
not an expert here... but it looks like a 16 inch flex will allow 975 cfm at .1 static pressure and it looks like an 8 inch flex will allow about 175 cfm at .1 static pressure. so by adding the 8 inch flex return to to the bedroom, you should be decreasing the static pressure in your system.
but since you are taking out a return grill on the 16 inch return, you might end up with some pretty fast air flow at the grill, which might make some noise. i dont know where your filter is,, but if its in the grill, you might be jumping up the fpm on the 16 inch return filter. if the filter is at the air handler, you should be fine.
bobinphx is offline   Reply With Quote
Old 03-01-2013, 09:55 AM   #17
thanks again. yes, the filters will be in both grills. So if the noise is not an issue (in hallway) is this okay for my system to reduce the static pressure as described?
zx7king is offline   Reply With Quote
Old 03-01-2013, 03:57 PM   #18
An old Tradesmen
Rewards Points: 7,378
How many supplies in bedroom, and what size are they,.
Old 03-01-2013, 05:00 PM   #19
two and they are the standard small floor ones.. ~11x4 .. there is also one in the bathroom attached. Thanks.
Old 03-01-2013, 06:32 PM   #20
Rewards Points: 1,514
Why not install a thin solid divider (such as thin plywood) vertically directly over the middle of the round duct below?
Cut a hole in the existing rectangular duct, directly above the existing round duct, to add more ductwork to extend the return ducting to other locations as desired.
Old 03-01-2013, 06:37 PM   #21
An old Tradesmen
You need to return as much air as you supply.
Old 03-02-2013, 09:00 AM   #22
Thanks Alan. I am moving the whole thing forward further under the stairs to enlarge the closet.
Will adding a return make a noticeable difference? thundercats HVAC 7 12-18-2012 10:37 AM
Adding return air supply Talgonadia HVAC 12 07-07-2012 02:35 PM
Central cold Air Return tom80 HVAC 3 11-01-2011 11:15 AM
Return Air Duct size question syclnjr HVAC 14 02-06-2011 04:48 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
