Singer Electric Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 12:44 PM   #1
I have a singer electric furnace model BCE 22013 24 11. What AC unit is compatible?
Thanks. I don't want to replace the Singer. Works fine and heats at a low cost. Just want to replace the AC unit.
John
jjakiun is offline   Reply With Quote
Old 06-02-2013, 01:06 PM   #2
MarginallyQualified
Rewards Points: 2,464
To replace you get the specs: BTU/Tons, physical size, etc.
A photo won't hurt one bit.
Find a local HVAC shop to work with you on the inevitable sheet metal changes that will be required and of course cleaning or replacing the refrigerent lines to the new condensing unit you also need.
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 01:14 PM
Coleman electric furnace won't turn off Chipappa HVAC 5 02-17-2013 05:04 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
