Singer Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2008, 06:47 AM   #1
singer air handler
I hope someone can direct me. I read an earlier post that someone was able to give information to someone about getting parts for an old Singer air handler unit. My singer unit is model bce 22008-24-11 and all I need is the drip pan. The size is 7.5" x 19.5" x 1.25" deep (the drain pipe is centered on the 7.5" side). The unit is old but works great except for the pan is rusty. My mistake for cleaning up the rust during the winter when there was no water in pan and when a/c started running, yep water leak. I have patched it but I know it is temporary. I have checked with my local appliance repair guy but said there is no way to get part. HELP. It's an easy replace just need pan. Thanks.
vicenzaborn is offline   Reply With Quote
Old 03-20-2008, 10:23 AM   #2
help
was wondering if you got any info on this handler i have the same 1 and it went poof??????
rusty is offline   Reply With Quote
Old 03-20-2008, 05:25 PM   #3
HvacWiz's Avatar
Rewards Points: 252
You can take out the pan, take it to any hvac shop where they fabricate sheet metal and they can make one up for you, should only take them about half an hour to do. I ve work on 3 singers in the past that were as you descibed an search as i might i could not find replacment pans for these, so i would have the guys just make on up for me, that was 8-9 years ago and they are still working with no leaks. goodluck
HvacWiz is offline   Reply With Quote
DIY Heat Pump/Air Handler replacement hennyh HVAC 62 06-18-2012 05:11 PM
Air Handler leaking when cycle ends mannaserv HVAC 1 09-04-2007 09:02 AM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
Drainage from air handler jack B HVAC 1 05-07-2006 08:35 AM
