Simple Hint When Upgrading From Classic Honeywell Round Thermostats - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 01:48 PM   #1
Rewards Points: 590
Simple hint when upgrading from classic Honeywell round thermostats
This may seem simple, but even Honeywell doesn't document this. On old round heat-only thermostats, you have only two wires, but there is no label on either one. The actual wire used could be just about anything, so you can't go by colors either. It seems that the terminal at roughly the six or seven o'clock position should be connected to "R" and the one at roughly eight or nine o'clock should be connected to "W". "R" and "W" are definitely the only terminals that operate, so if you still don't get heat, perhaps you only need to reverse them.
Also, if you're upgrading to a Honeywell programmable thermostat, don't forget to leave enough clearance on the right side so that you can replace the batteries without dismounting the thermostat.
operagost is offline   Reply With Quote
Old 02-02-2010, 04:32 PM   #2
An old Tradesmen
Rewards Points: 8,184
On the round T87F thermostat, it makes no difference which of the 2 wires in a heat o nly install get connected where.
Myself. I always tried to connect the supposed hot wire to the 8:00 terminal. And what would normally be the white wire to the 7:00 terminal. Even though it made no difference.
When replacing any thermostat. A person should always check to see where the wires are connected at in the furnace.
are all classic "round" Honeywell therms low voltage? nykije HVAC 2 11-18-2009 06:33 AM
