Simple Air Return Grille Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2013, 03:01 PM   #1
Simple air return grille question
Bear with me...
My upper floor has carpeting and had triangular air return grilles like this...
http://www.installerstore.com/triang...urn-grill.html
As they were 30 years old and I am changing trim to white, I purchased flat grilles like so...
http://www.installerstore.com/White-...rn-Grille.html
I plan on changing the flooring to laminate or hardwood within the next year or so. I like the flat style of vent because it doesn't stick out.
When I put on the new vent, there is a gap of about an inch at the bottom where there is no subfloor, just the carpet. Is this type of vent not to be used in this situation, or will I be able to extend the hardwood flooring an inch or so so that the entire bottom of the grille will make contact with the flooring?
I'm just wondering if I am only to use a triangular grill in this circumstance or if it's acceptable to use the flat one and deal with the flooring at a later time.
eveready11 is offline   Reply With Quote
Old 05-25-2013, 03:18 PM   #2
Rewards Points: 6,652
You still have some work to fix the missing subfloor and wood flooring, where the old vent was at.
Old 05-25-2013, 03:24 PM   #3
So I should return these and go back to triangular ones?
Old 05-25-2013, 04:22 PM   #4
Go with what works best for you. The Angled ones are like what we have in our house, due to it is over 75 years old, and personally I like them, because you get a better deflection with the gate over the opening, vs. flat fronted grills.
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 07:54 PM
Simple circuit question for a novice mwfooshecpa Electrical 3 01-31-2011 02:54 PM
HVAC return vent location question fatboy HVAC 1 03-10-2008 08:56 PM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 03:48 PM
return grille farrington135 HVAC 2 07-20-2006 09:31 PM
