Silly Question - Installing Ac Boots - HVAC - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 09:56 PM   #1
Renovating My Land Yacht
Rewards Points: 616
Silly question - Installing ac boots
I just went and bought a bunch of the insulated boots in prep for re-doing the ducting. How the heck to you install these things?? There is no room for a drill, do you just reach up in there with a girly hammer? There is no flange etc that I can attach them with.
RJ
forcedreno2012 is offline   Reply With Quote
Old 04-18-2013, 10:12 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
would you happen to have a picture of them?
HVAC1000 is offline   Reply With Quote
Old 04-18-2013, 11:13 PM   #3
Rewards Points: 616
Here it is. The larger ones I think I can fit the drill in with some gymnastics but the smaller ones I have no idea as there is no flange.
Old 04-19-2013, 12:33 AM   #4
HVAC1000's Avatar
Ya the ones I usually get from the supply houses have flanges for nailing or to screw to. With those ones I just secure the boots to the pipe and make sure the pipe is strapped and secured in place.
Old 04-19-2013, 12:42 AM   #5
Rewards Points: 616
Yes I was a little surprised that there wasn't a flange I am very happy with the quality so hopefully we can get them to work. I think what you are saying on the smaller ones connect them to the elbow and then secure the elbow to the joist ilo of trying to attach the box itself? And one more question if I may is okay on the larger ones to just screw them to the joist through the insulation?
Old 04-19-2013, 01:34 AM   #6
HVAC1000's Avatar
If I'm picturing this right it should be fine but I'm not seeing this first hand. Just so long as everything is secure and solid in its final location. Remember to leave it stubbed out 1/2 inch so whoever Sheetrocks doesn't accidentally cover it up. Good luck. I still enjoy doing sheet metal and duct work, even after all these years of doing service and maintenance tinning is how I started out. It is great to look back and see what a good job you have accomplished with your duct work
The Following User Says Thank You to HVAC1000 For This Useful Post:
forcedreno2012 (04-19-2013)
Old 04-19-2013, 01:57 AM   #7
Rewards Points: 616
Hmmmmm....fancy a trip to Mississippi??
Yeah I agree on the satisfaction of doing it yourself, no matter how small its always cool to look back and say "I did that"
Okay will forge ahead. Thanks for the quick responses.
Old 04-19-2013, 09:26 AM   #8
HVAC1000's Avatar
No problem. If you have anymore questions there are lots of smart people here. Someone's bound to have an answer haha
going to be installing Saniplus, venting question dwcopple Plumbing 4 04-04-2012 07:32 PM
Installing shower door question Pawl Windows and Doors 1 03-24-2012 09:28 PM
ugh, very simple electrical question - installing ceiling light diy'er on LI Electrical 6 02-16-2010 10:23 AM
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 05:21 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
