Silicone Nitrate Upgrade - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 08:36 PM   #1
Silicone Nitrate upgrade
I have a Intertherm/Nordyne MM in a trailer.Circa 1996.It is Direct HSI with no flame sensor rod.The control mod it Universal Electronics 1018 series.Model 1018 204-9523.I am very interested in the new silicone nitrate igniters.Since these won't sense flame as the carbide type will.If i add a flame sensor to a control that has this provision,will I be able to use the nitrate type? Thanks!
fatvinny is offline   Reply With Quote
Old 11-06-2011, 08:46 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
For why?
Doc Holliday is offline   Reply With Quote
Old 11-06-2011, 09:06 PM   #3
I want the added life cycle.Just FYI.I'm no stranger to mechanics.I am an OTR owner/operator. I own my rig.I service/overhaul my own stuff.Tractor and trailer.I also service my own HVAC equipment and everything else around my house.The reason I looked for this forum.I'd just like to know if this is doable and if you or anyone else may have any advise.I would be very grateful.
Old 11-06-2011, 09:22 PM   #4
Never done it myself but if the ignition control has a space for a flame sensor then your plan should work.
The Following User Says Thank You to Marty S. For This Useful Post:
fatvinny (11-06-2011)
Old 11-06-2011, 09:57 PM   #5
Well then yes, you can. It's considered an upgrade.
Hope this helps.
http://www.ignitersdirect.com/igniter_faq.htm
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 11-06-2011, 10:01 PM   #6
As you already know, a nitride ignitor will not sense a flame and as Marty said, you have to have some place on the ignition for a flame sensor or your furnace will simply continually shut itself off and then lock itself out.
Old 11-06-2011, 10:16 PM   #7
Thanks a lot Doc Holliday and Marty S.I truly do appreciate the info.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 04:52 AM
silicone on silicone caulk ponch37300 Kitchen & Bath Remodeling 2 05-09-2009 09:11 AM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 09:03 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 11:23 PM
