Silfos..... - HVAC - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 10:02 PM   #1
Rewards Points: 616
silfos.....
I just bought 100 sticks of 15% silfos.... i almost pooped myself when I looked at the bill......... are you kidding me cant be that much.... it was .34 cents a stick when I started......
carmon is offline   Reply With Quote
Old 04-25-2012, 10:23 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
One 5% silver sodder canister (28 sticks, I believe) was $57 and change last week. I've never understood the purity thing of the 15%, as if that makes you better at brazing. I've never once had a problem with 5%.
I'm good with it.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-25-2012, 10:33 PM   #3
Rewards Points: 616
My guys do not like 5% silfos........ does not flown nearly as good into the joint...... i am doing an ultra low now that the refrigerant is $689.00 a lb ..... i think i will use 15 % for this one..
Old 04-25-2012, 10:42 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
I use 6% on normal everyday copper brazing. If I have to braze to brass or to large (1 1/4" or larger) compressor joints i will use 15%. If I can't get that to flow then clean the joint, flux, and 45%.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-26-2012, 05:05 AM   #5
An old Tradesmen
Rewards Points: 7,826
Yep, it sure is expensive these days. And I only use 45% if I absolutely have to.
Old 04-26-2012, 06:07 AM   #6
Rewards Points: 1,216
" Cascade F-13?"
COLDIRON is offline   Reply With Quote
