-   -   Sight Glass Moisture Indicator (http://www.diychatroom.com/f17/sight-glass-moisture-indicator-48267/)
zootjeff 07-07-2009 12:54 AM
59 Attachment(s)
Hi,
I want to install a sight glass on my heat pump liquid line. Seems like Emerson makes them as well as several other manufactures.
Here is one I can get for 12 bucks delivered:
http://cgi.ebay.com/ebaymotors/ws/eB...EF:MOTORS:1123
Does anyone know much about these? Do they work very well? Should I spend 40 on one rather then 12? What is the take rate on these, do people use them on new installs?
-Jeff
veesubotee 07-07-2009 08:11 AM
Originally Posted by zootjeff (Post 298292)
Hi,
-Jeff
Of the dozen or so of contractors I interviewed, only one said that he installed a sight glass on every installation.
My guess is that he used it to quickly check the charge (bubbles) as he wasn't conversant with such things as static pressure, superheat, sub-cooling.
Needless to say, he didn't get the job.
V
kennzz05 07-07-2009 01:58 PM
only works if youre system is equiped with a txv
zootjeff 07-07-2009 04:22 PM
59 Attachment(s)
Really? how is a TXV going to affect moisture content?
My system will have one, but that doesn't make sense to me.
qbert 07-07-2009 04:32 PM
Usually install them on new installs after drier before evap ,moisture indicators can be a helpful troubleshooting tool but not necessary.
yuri 07-07-2009 06:52 PM
If you have pulled a proper 500 micron vacuum etc you won't have a moisture problem and need the indicator. Sightglasses can eventually leak freon and I won't use them. On refrigeration systems, Yes. Using superheat/subcool/approach methods and or weighing in the charge is all I use.
hvaclover 07-07-2009 07:45 PM
Gotta dis agree with you to some degree Yuri.
I put one on a system to day cause i suspected I wasn't getting a full liquid head. I was right right. Needed 1 1/2 lbs of R22 to make it right.
My subcooling and superheat were within one and half degrees of spec and spec called for with +/- two degrees.
My line set was long and in this case the sight glass helped as the TXV could not be adjusted to compensate line set length.
yuri 07-07-2009 08:23 PM
I agree they can be useful but leave them there long enough and some can leak. I would not want someone not understanding superheat/subcooling etc and only using a sight glass. Good techs understand the fundamentals and not just using shortcuts. Here's one for you. Lots of furnaces nowadays have 3 ton capable blowers but a 1 1/2 ton unit is installed. Do the installers slow down the fan or just charge it on high speed and let it rip. Kind of blows away the logic of the charging tables? I find them left on high from the factory a lot.
hvaclover 07-07-2009 08:42 PM
Yu're 'spossed to change motor speeds??:eek:
:laughing:
yuri 07-07-2009 08:49 PM
Some of these blowers have so much capacity it blows Granny's bedcovers off and freezes the old gal. Not to mention whistling etc. Put er down to red and it works fine.:thumbup:
psilliman001 07-07-2009 09:33 PM
Jeff............
...he means the sight glass can only be used for charging a txv system only , you can't charge a piston or fixed orfice system with a s.g. are you only looking to see the moisture content with this glass??? What is your reason to have this item , as you'll need to perform all the work the other guys have mentioned . it hardly seems worthwhile to do all that is required if you're not coversant with sh , sc , db & wb to properly charge your unit . Please don't take offense at my comments as i don't know your experience level . The way you ask your question makes me wonder....Please be careful with liquid refrigerant:(
zootjeff 07-08-2009 01:47 AM
59 Attachment(s)
I don't plan to install it myself, but I do plan to buy it myself if I do buy it. I've found a guy to do the brazing charging and setup, I was just curious if I should get one of these and how people decide whether or not to get one or not on a brand new Install.
-Jeff
hvaclover 07-08-2009 06:49 AM
Ten bucks says he gets condensation inside the SG and wipes away the moisture indicator. :whistling2:
I know it did me:censored: Next one I'm gonna flare.:yes:
zootjeff 07-08-2009 12:00 PM
59 Attachment(s)
Can you re-phrase that? I have know idea what you just said.
hvaclover 07-08-2009 12:03 PM
Sorry. It's the way you have to heat sink the SG or you get condensation on the inside glass.
