Which Side Are Connections Of Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 11:41 AM   #1
Which side are connections of furnace?
I am planning the location of a new furnace.
For upflow, I was told the cold air return can be on either side.
How about gas & electrical connection? I'd like to have the gas pipe run to the correct side so I don't need a long flexi to wrap around.
Also, I was playing with the idea of mounting horizontally so I can keep some floor space. Where do the connections go on a horizontal model?
acerunner is offline   Reply With Quote
Old 09-26-2010, 06:20 PM   #2
Chicago, IL
Michael Thomas's Avatar
The manufacturer's installation instructions will list the allowed installation orientations, and usually illustrate the allowed connections.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-26-2010, 06:38 PM   #3
Most all furnaces facilitate electric and gas installation on either the left or the right side.
brandonmcginnis is offline   Reply With Quote
The Following User Says Thank You to brandonmcginnis For This Useful Post:
acerunner (09-29-2010)
Old 09-26-2010, 10:17 PM   #4
fabrk8r
fabrk8r's Avatar
Most upflow furnaces can have the return on either side or through the bottom. Gas and electrical connections can come in either side, as brandonmcginnis stated.
Supply and return are connections on a horizontal furnace are usually one at each end (imagine upflow with supply at top and return at bottom and tip it on it's side).
Michael Thomas has a good point...the installation manual should cover all the bases.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Venting med. efficiency furnace and H2O heater thru wall? cbrc5eric Building & Construction 2 04-02-2010 11:07 PM
Have an oversized furnace turfgrass HVAC 5 02-22-2010 03:48 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
