Should You Cover The AC Condensation Drain Opening In The Attic? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 11:32 AM   #1
Rewards Points: 94
Should you cover the AC condensation drain opening in the attic?
Hi,
I had a block of my AC condensation line which I cleared with the use of a wet/dry vac-- suctioned from the outside opening of the drain pipe. I then went to the attic to pour some diluted bleach into the drain opening but I did not see any type of cover for this opening. Should there be a cover for this and if so can I just use a bottle cap to cover this opening or should I leave it open? Thanks
shovad is offline   Reply With Quote
Old 06-28-2013, 12:04 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 382
leave it open, needs 2 B open to allow the drain to not get airlocked and siphon/drain properly.
Cutting a hole in floor drain cover for drain hose Rav Plumbing 8 12-21-2012 12:50 PM
Attic Ladder that fits 21 by 27 inch opening? nathanleg Remodeling 5 04-03-2012 08:33 PM
Condensation on attic A/C ducts unlvrebel HVAC 1 08-29-2010 05:31 PM
How to unclog condensation drain pipe in attic rpguy4 HVAC 6 06-05-2010 01:07 PM
large drain cover for tub? renee18103 Plumbing 1 03-15-2008 07:06 AM
