Should The Return Vent Have Colder Air Than The Tstat? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 08:46 PM   #1
Should the return vent have colder air than the tstat?
Common sense would tell me the return should be the hottest, but that is not the case in my house.
tstat seems to always be 3-5 degrees warmer.
I have a ceiling return vent that is located by the tstat in the hallway.
blarose is offline   Reply With Quote
Old 07-22-2011, 10:24 PM   #2
An old Tradesmen
Rewards Points: 6,922
Is supply air being drawn into it.
Old 07-22-2011, 11:15 PM   #3
The vents are in the bedrooms and den, but seems to be getting some of that air in the return instead of strictly the hot air.
Old 07-23-2011, 06:11 AM   #4
Rewards Points: 1,216
Actually that is the perfect spot to have the T stat it will sense the air of the total house if it is ducted properly.
That's where mine is and it keeps the temperature of the the whole house the same, it actually senses the air returning to the air handler instead of sensing each room.
COLDIRON is offline   Reply With Quote
furnace cold air return vent placement flee HVAC 6 03-18-2011 12:06 AM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Converting a return into a normal vent? Red Squirrel HVAC 0 11-04-2009 08:58 PM
return vent size change philip18 HVAC 7 10-24-2009 11:18 PM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 03:39 PM
