Should Replace AC/furnace Or Cross Fingers? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 09:40 AM   #1
should replace AC/furnace or cross fingers?
Hi,
Would like some help here. I have a condo that I'm' not looking to spend much more money on. the technician called and said that there was little freon and suggested replacing the unit. It would need a crane (3 story high) to the AC upon the roof.
He quoted a Westinghouse 2.5ton AC with 70,000 BTU furnace at close to 7k. Does this seem reasonable? Are Westinghouse furance/AC good? Thanks!
junkemail0707 is offline   Reply With Quote
Old 05-05-2011, 02:58 PM   #2
Rewards Points: 380
Why wouldn't you just get him to repair the leak? Is the unit old or have a history of repairs? How old is the furnace? Have you had other problems that make you think the equipment has lived its usefull life? How long do you intend to keep the condo?
HVACDave is offline   Reply With Quote
Old 05-05-2011, 03:38 PM   #3
An old Tradesmen
Rewards Points: 6,944
Sounds cheap, crane rental isn't cheap.
Old 05-05-2011, 09:35 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
I'm confused, is this a gas package roof top unit or a split system?
Doc Holliday is offline   Reply With Quote
Old 05-07-2011, 05:31 AM   #5
biggles's Avatar
an 8 hour day of nitro and vacuum testing will find the leak you don't need to replace the both ends...and if so they will use the same pipe run anyway that could still have the original leak with a new system...
Old 05-08-2011, 06:47 PM   #6
get a second opinion and price
mrairflow is offline   Reply With Quote
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Ok to use a sanitary cross in a wet vent? peeks Plumbing 1 10-03-2005 04:35 PM
