Should I Worry About Vibration? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 10:16 PM   #1
dit
Should I worry about vibration?
I had my (central) A/C and furnaces (2 units) replaced over the past few years. I noticed that the downstairs A/C and heat blow hard (sounds like a wind tunnel) but I am noticing a vibration coming up from underneath the house. I am sitting on the couch and can feel a vibration when the A/C is running. And it has been running a lot this summer.
Could the A/C company have put in a unit that is overly powerful for the house size? What else could be causing this? I would like the loud blowing to be more quiet, but the vibration worries me more in that it might cause foundation or structure damage.
And who would I call to consult about this? I am not sure I trust the A/C guys, especially if they installed too strong of a system in the first place (the second unit was installed by another company for the upstairs and I think that one is fine, but it's significantly smaller in size, and I am referring to the part of the system which is outside, not the parts that are in the attic and crawlspace). Would I contact a home inspector or general contractor?
As you can tell from what I wrote, I can't do this as a DYI thing, since I don't understand any of this. I'm just wondering if it's normal, and if not, what might be causing it and who I should call for help. It is hot here and the A/C runs a lot. I never recall this vibration or as much noise before I had the units replaced, but I may not have been paying as much attention.
dit is offline   Reply With Quote
Old 07-12-2010, 07:32 AM   #2
An old Tradesmen
Rewards Points: 6,464
Could be its oversized. could be your duct work is undersized for the unit.
Neither a GC or home inspector would be who you call.
Why not call the last company you had out. That you liked.
frigidaire dryer has excessive vibration gmoliver Appliances 17 09-10-2015 11:13 PM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 01:49 PM
ducted range hood: vibration and air coming out of top vent ilyaz Plumbing 0 04-09-2010 02:36 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Attic fan vibration ptedone Carpentry 5 12-12-2006 07:53 AM
