Old 12-22-2007, 01:42 AM   #1
Should I use 2 Furnace Humidifiers?
I have a fantastic Carrier Infinity 96 System with the Infnity Controller and an Aprilaire 600 Humidifier. I love the system!!!
But because my house is so old and leaky the AprilAire keeps on running, Using more and more water down the drain(as it is the one with the humidifier panel) the humidity doesn't reach the automatic setting that the controller sets (Normally around 35%)
I Know that I should insulate and caulk the house, but that is in the distant future. Should I put in a second humidifier?? Would the create problems with the furnace or A/C?
Thank you.
Adrianjohnm is offline   Reply With Quote
Old 12-22-2007, 08:12 AM   #2
Electrician
Install a steam humidifier, Will create humidity even if furnace is not calling for heat.
chris75 is offline   Reply With Quote
Old 12-22-2007, 09:01 PM   #3
Union HVAC Tech.
35% is too high a setting. I second the steam unit.
bigMikeB is offline   Reply With Quote
Old 12-24-2007, 03:13 PM   #4
Electrician
I keep my house at 40%, feels comfortable to me and no condensation on the windows... I also use a honeywell humidistat with an outdoor sensor so I dont need to keep adjusting the humidistat.
Old 12-24-2007, 04:30 PM   #5
Union HVAC Tech.
Most houses will do fine at @68F and 25-30%rh. I have never seen any place other than a computer suite run at 40%.
Old 12-24-2007, 11:43 PM   #6
Red face
I should mention I live in Toronto Ontario. The winters are pretty cold and dry here.
Some have mentioned that 35% humidity is alot.
I don't know, but everywhere that I read, including Canadian Mortage and Housing Corp. suggest that 35 - 40% huidity is the best rating,.
My humidifier can hardly keep it aound 26% because the house is so old and drafty.
I will look into the steam hunidifier,
Thanks all.
Living cold be comfy in Toronto...Thanks to my Carruer Infii
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
furnace and or electrical problems tuasoi General Discussion 4 11-29-2007 01:50 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
