-   -   Should I use 2 Furnace Humidifiers? (http://www.diychatroom.com/f17/should-i-use-2-furnace-humidifiers-14652/)
Adrianjohnm 12-22-2007 12:42 AM
I have a fantastic Carrier Infinity 96 System with the Infnity Controller and an Aprilaire 600 Humidifier. I love the system!!!
But because my house is so old and leaky the AprilAire keeps on running, Using more and more water down the drain(as it is the one with the humidifier panel) the humidity doesn't reach the automatic setting that the controller sets (Normally around 35%)
I Know that I should insulate and caulk the house, but that is in the distant future. Should I put in a second humidifier?? Would the create problems with the furnace or A/C?
Thank you.
chris75 12-22-2007 07:12 AM
Install a steam humidifier, Will create humidity even if furnace is not calling for heat.
bigMikeB 12-22-2007 08:01 PM
35% is too high a setting. I second the steam unit.
chris75 12-24-2007 02:13 PM
I keep my house at 40%, feels comfortable to me and no condensation on the windows... I also use a honeywell humidistat with an outdoor sensor so I dont need to keep adjusting the humidistat.
bigMikeB 12-24-2007 03:30 PM
Most houses will do fine at @68F and 25-30%rh. I have never seen any place other than a computer suite run at 40%.
Adrianjohnm 12-24-2007 10:43 PM
RE: 2 Humidifiers
I should mention I live in Toronto Ontario. The winters are pretty cold and dry here.
Some have mentioned that 35% humidity is alot.
I don't know, but everywhere that I read, including Canadian Mortage and Housing Corp. suggest that 35 - 40% huidity is the best rating,.
My humidifier can hardly keep it aound 26% because the house is so old and drafty.
I will look into the steam hunidifier,
Thanks all.
Living cold be comfy in Toronto...Thanks to my Carruer Infii
