Old 11-12-2007, 10:30 AM   #1
Should I seal return air duct?
I got a new gas pak last year. The contractor hooked the return air duct to it using duct tape. When I went under the house yesterday I could hear air leaking.
Should I seal it up air-tight with mastic, or is it better to leave it leaky (to allow fresh air into the house)?
phareous is offline   Reply With Quote
Old 11-13-2007, 12:14 AM   #2
no loose ends
Though sometimes fresh air in a house is a good idea, from the basement or from under the house doesn't sound too wise. Mastic would probably introduce an uncomfortable odor. Get a water-based latex duct sealer from your local HVAC supplier if you can't get the contractor to come back out and do HIS job.
undone is offline   Reply With Quote
Humidifier in Return duct TurningColorz HVAC 2 10-29-2007 06:59 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Central Air return duct location backpacker2 HVAC 3 05-28-2007 11:07 AM
Heater Return duct - Moved to HVAC forum backpacker2 HVAC 1 05-16-2007 12:30 PM
