Should I Replace My Boiler? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 07:01 AM   #1
Rewards Points: 93
So a few years ago we bought an old house and the inspector said that we should replace our forced hot water heat boiler because it was very old, old enough that he didn't see a date anywhere. Now while this is probably good advice I would feel better about replacing the unit (it gives us no maintanance problems) if I could calculate how much we would save per year by replacng it. In order to do that I need to know the efficiency, so I looked at the information plate on the unit (Weil-Mclain) and it said:
Input (BTU) 210,000
Output (BTU) 168,000
So I figure that I can calculate the efficienfy, 168/210=0.8 or 80%. Which is much better than I had expected so I thought I must be missing something.
That being said I found this page advertizing new boilers (I know this particular one is too small to use for my replacement):
http://www.homeperfect.com/weil-mcla...FcU-Mgod5DYA1Q
On this page they also show the BTU input and output as 105,000 and 80,000 respectivley, which I would think means 80/105=.76=76% but the page lists the efficiency as 95.3%?
What am I missing?
jsbeckton is offline   Reply With Quote
Old 11-27-2012, 10:04 AM   #2
Rewards Points: 610
Ya got me. Doesn't make sense..output should be much higher..unless theyt are stating minimums at worst case scenarios..system design wise...I would call the manufacturer rep directly to discuss...hopefully someone else will be able to explain
techpappy is offline   Reply With Quote
Old 11-27-2012, 12:17 PM   #3
Rewards Points: 1,294
I believe that rating is for 100% fire rate. These are what are refered to as Modulating fire boilers. Once the boiler is up and running at temp the flame modulates back to as low as 20% fire. This is where the efficency comes from. I installed one of these at my father-in-laws house a couple years back. 2800 Sf house, ultra 80 boiler. Took the house from 1 zone to 3 zones and added a 50 gal "boilermate" water heater. Western NY winters and never had a cold day in the house. Also lowered his heating bill by almost 40%. Most of this was due to the way we zoned this house.
If you have one installed, make sure the installer knows how to do the install properly. These are not plumbed the same way as a conventional boiler. They need to have the "Boiler Loop" installed to prevent cold shocking the heat exchanger. This install requires a min of two circ pumps.
Pretty cool to watch the flame modulation guage as the unit is running.
danpik is offline   Reply With Quote
Old 11-27-2012, 12:56 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Input (BTU) 210,000
What am I missing?
You are calculating/looking at Combustion efficiency which is the amount of heat you get from burning 1 cu.ft natural gas. That is not the same as "operating efficiency" AFUE google AFUE for more info. A sealed combustion boiler costs less to run as it takes no air from the house to feed the fire which is what your old one does. We use AFUE which is like the EnerGuide ratings/stickers on appliances to tell you how much it costs to run per day so you can compare the actual operating costs.
Old 11-27-2012, 01:33 PM   #5
Smacks palm to forhead. Dooooh, sometimes the ole grey matter needs reminding.
Old 11-27-2012, 02:49 PM   #6
Rewards Points: 93
Ok, so what I am gathering is that these numbers can't be used to determine efficiency, I need to google the model and try to find the AFUE rating which I can then use to compare operating costs to a newer model. Right?
I just replaced the hot water heater a few months ago, too bad i didn't know I could have added a "boilermate" heater!
Old 11-27-2012, 03:06 PM   #7
You can add one to any biler system. Most older boilers are so oversized that they will work fine...just need to add an additional zone. These newer ones have a domestic hot water priority feature that allows the boilermate to get the hot water over the other zones so the recovery is awesome.
You can always sell the current heater you have or hook it up as a backup. The nice thing about the boilermate heaters is they have no fire burning under them. I know of one in my buddies house that is going on 25 years old and never had a problem
Old 11-27-2012, 04:05 PM   #8
An old Tradesmen
Rewards Points: 6,906
Unless your current boiler is a steam boiler, good chance its over sized for your home. A proper sized boiler will save you more money they just getting a new boiler of the same size.
The Weil McLain Ultra gas boiler is a mod con boiler, and an save you 30% or more on your heating bill.
Old 11-27-2012, 04:53 PM   #9
Rewards Points: 93
Ok, so I tried to look the model up and didn't come up with anything (Weil-McLain P-E-&, Series 3). Anybody have any info on this model? Guess this is a sign of how old it is. FYI, our house is about 2800 sqft not counting a full basement. How oversized is it?
Think I saw one site that said 75BTU/sqft which would put it at 210,000BTU which is what this one is. How oversized is that?
Old 11-27-2012, 05:54 PM   #10
Rewards Points: 93
Sorry, Model "P-E-7" not P-E-&
Old 11-27-2012, 07:48 PM   #11
Items wanted: Time
Rewards Points: 150
heat calcualtion required to determine the "exact" size for your home, anything short of that and it is a guess.
NiNe O is offline   Reply With Quote
Old 11-28-2012, 04:03 AM   #12
An old Tradesmen
Probably around 80,000BTUs, of course thats just a guess from my chair.
Old 11-28-2012, 05:41 AM   #13
Any good installer/salesman will do a proper heat load calculation on your house before they sell/install anything.
I do what we call "overbook" installs for a local company. If there is a large call for installs at my friends co. they call me to help out. I do about 15-20 installs durring the heating season. Mostly boiler replacements. I don't think in the 25+ years I have been doing this that I ever changed a heating plant "BTU for BTU" In my father-in-laws house, I went from a 175,000 BTU unit down to a 80,000 BTU unit. Granted, it went from a 80% to a 93+% which helped but the heat load calc came in right near 80,000. Probably the worst case I ever saw was a 250,000 BTU forced air unit in a well insulated 1500 SF house. I did not work the job, but from what I remember they also had something like 4 times the tons of cooling that was needed. The previous owner was one of those..."some is good, more is better, biggest is best" kind of people.
If you can post a picture of it one of us here might be able to tell roughly the age. Might not be as old as you think. Aside from the lower efficiency, age is not a good reason to just change out a boiler. I changed out my 1959 boiler a few years back,not because it was old, but I needed to move it from the center of my basement and into a utility room I was building in the corner. this was done primarily because I needed to remove the chimney from the center of my house.
Old 11-28-2012, 10:47 AM   #14
Rewards Points: 93
Ok, contacted the manufactuer and they said that model was made between 1970-75 but that the don't have an efficiency information on units of that age. Can anybody venture a guess as to what it might be or give me a bounding value, say that it can't be more than 65% or something like that?
Old 11-28-2012, 10:52 AM   #15
Items wanted: Time
Rewards Points: 150
Someone not setting the gas pressure correctly would cause a swing of 10% or more in lost efficiency. You would need a team of engineers to figure that one out.
Low water cutoff keeps shutting boiler off dolfish HVAC 7 12-06-2010 04:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 04:57 AM
Replace Boiler or try to improve? bootsnixon HVAC 16 11-11-2009 05:22 PM
how hard to replace an oil boiler? diy001 HVAC 4 10-03-2009 10:29 PM
