Should I Relocate My AC Unit To Build A Deck? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 12:30 PM   #1
Should I relocate my AC unit to build a deck?
My air-conditioning unit is sitting outside the house right where I want to build a deck. Can I build over the AC unit, or should I move it?
tom_matthews is offline   Reply With Quote
Old 06-24-2009, 12:36 PM   #2
How far off the ground will the deck be?
Will there be enough room to walk under & service the AC
If not the AC needs to be moved
Old 06-24-2009, 01:48 PM   #3
the deck will be about 1.5 to 2 feet over the unit. I was wondering how much free space for airflow I need to maintain around the unit.
Old 06-24-2009, 01:52 PM   #4
I'd worry more about HVAC guy getting in there to make repairs or service the unit. I'm not sure how much space they need. But I don't think I'd want one that close under the deck
Old 06-24-2009, 02:08 PM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I agree with Dave - Figure the shroud may need to be removed some day and that lifts up as I recall. So, if you unit is 2' tall i would not build a deck unless you have at least 2' clearance from the top of the unit. Really - do what the manufacturer recommends for clearance.
Also - consider sound and air. the outside units are noisy, do you want that under your deck? They also blow warm air, that air will blow up people skirts.
Brik is offline   Reply With Quote
Old 06-24-2009, 02:26 PM   #6
Why chance it.
Suppose you do build over the unit and discover the system is no longer cooling adequately. Now you've got twice the work to either move the unit or the deck. And I bet an HVAC guy looking at that job will quote you higher to accommodate all the bumps on his head.
dac122 is offline   Reply With Quote
Old 06-24-2009, 02:35 PM   #7
sktn77a's Avatar
Rewards Points: 390
Most manufacturers specify at least 60 inches uninterrupted clearance above the condensers.
sktn77a is offline   Reply With Quote
Old 06-24-2009, 02:40 PM   #8
30 year tech
hvac122's Avatar
Ditto. Do not build unless there is at least 5' above unit. And expect to pay more for it to be serviced. Move it someplace where it can breath.
hvac122 is offline   Reply With Quote
Old 06-24-2009, 02:43 PM   #9
Handyguy
Brik's Avatar
no comments on the upskirt consideration?
Old 06-24-2009, 03:31 PM   #10
You said that like it was bad thing
Old 06-24-2009, 04:00 PM   #11
DIY'r
ScottR's Avatar
Can't even implement that feature with my unit..
ScottR is offline   Reply With Quote
Old 06-24-2009, 08:22 PM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
She can ride shotgun in my van anytime!
Old 06-24-2009, 08:32 PM   #13
So what's wrong with your "unit"
If you look at the prior pic, And then read that comment
Old 06-24-2009, 09:12 PM   #14
Home Air Direct's Avatar
New units are quiet............until you sit on top of one And, if they are working properly, they blow hot air....UP (yes, even those funny looking Tranes You really don't want that if you are going to spend any time all on your deck, during "being on the deck time of year".
When I moved in this house nine years ago (it was my girlfriend's) she had a deck built over the AC. It was one of those horizontal chrysler airtemp's. It was insanely loud, and the heat was unbearable. As soon as it died, which I think was hastened by the fact it was trapped under the deck, I moved it around the side of the house.
Don't do it.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
DougFir Deck - Stain Before or After build? mntnvew Carpentry 15 06-09-2015 12:55 AM
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Fire pit build over existing concrete deck - am I headed for trouble? mitchcos Building & Construction 10 04-15-2009 08:26 AM
Anyone ever build a deck above the outside hatchway? JT Rock General DIY Discussions 2 04-04-2009 02:09 PM
