Should I Insulate My Metal Ducts? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 08:55 PM   #1
should I insulate my metal ducts?
I live in a bungalow. I have a series of 5" round metal ducts running in the floor joists.
I am currently finishing the basement and everything is exposed now. I wasn't going to touch any existing ductwork but I did notice that they are quite hot to the touch some times. My local big box sells 5" round by 10' long insulating sleeves for ~$15. they claim R value for 4.5 to 6.
So, what do you think? is this a worthwhile investment of time and money?
hswerdfe is offline   Reply With Quote
Old 12-17-2012, 09:29 PM   #2
An old Tradesmen
Rewards Points: 6,148
6 one way, half a dozen the other.
The heat they put off also helps to keep the floor above them warm. may not feel as comfortable if the floors are cooler.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (12-19-2012), hswerdfe (12-18-2012), jagans (12-17-2012)
Old 12-17-2012, 09:42 PM   #3
concretemasonry's Avatar
Rewards Points: 2,570
You are not really losing any heat since it is still inside the house. It is just being distributed a little differently (if you do not have any leaks).
dick
concretemasonry is offline   Reply With Quote
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
carmon (12-17-2012), hswerdfe (12-18-2012)
Old 12-18-2012, 10:03 AM   #4
Rewards Points: 314
Insulation is good, but duct mastic might be better bang for the buck. Seal all the joints and seams with mastic. I might also be a good time to clean the ducts one time before you seal them up!! (diy is fairly easy)
now others may disagree, but if it was me, I would lay in some standard unfaced fiberglass all along the sides and bottom (you may need to thin the fiberglass on the bottom). The r13 rolls are cheap and by insulating the sides and bottom, you will still let a little heat out to possibly keep the floor above warm...
bobinphx is offline   Reply With Quote
The Following User Says Thank You to bobinphx For This Useful Post:
Old 12-18-2012, 11:36 PM   #5
Thanks all.
For the record I have decided not to insulate them for now.
bobinphx: the reason I was considering it in the first place is that I was already doing exactly what your propose "Sealing the ducts".
Grounding Metal Boxes and Outlets - Confused by Something Simple ALFisher Electrical 42 04-28-2015 01:14 PM
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 04:18 PM
insulate ducts, freezing basement kree Building & Construction 1 05-19-2012 08:50 PM
Metal roof questions Zedman53 Roofing/Siding 20 02-04-2012 12:32 PM
metal vs shingles av-geek Roofing/Siding 39 01-24-2012 05:25 PM
