Should I Be Alarmed About A Cardboard & Styrofoam-lined Intake Vent? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 09:40 AM   #1
Rewards Points: 53
Should I be alarmed about a cardboard & Styrofoam-lined intake vent?
We purchased a house about 3 months ago. It's a 1955 ranch-style - some bits are modern and some are 1955 original. While painting a while back, I removed the heating intake vent cover (I assume that's what it is - it's covered by magnetic panels at the moment), and saw the image below. I'm not sure whether that's what things are supposed to look like and I'm looking for a "that's pretty standard," "that ain't great but it ain't a big deal for now," or "holy nuts - what fool installed that?"
This area is at the main level ceiling - just below the attic. The metal HVAC line runs about three feet below this image and just terminates, open-ended, in the middle of a 2' x 2' shaft that runs from there down the basement ceiling, just above the boiler. A few electrical cords use that shaft as a conduit. The shaft is also home to a 1" water pipe that is connected to nothing whatsoever.
Our house has oil heat/water boiler/baseboard radiators. It has a totally separate central A/C system.
IMG_2764 by DC Orbiters, on Flickr
corsulian is offline   Reply With Quote
Old 08-24-2012, 10:14 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If you were in Omaha ne the first words out of my mouth would be madera heating and cooling!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 10-04-2012, 01:58 PM   #3
Rewards Points: 53
Thank you. I'm not sure what that means.
Does anyone else have a reaction to this photograph?
Old 10-04-2012, 04:29 PM   #4
plummen's Avatar
Madera was a big hack job hvac contractor in town!
The Following User Says Thank You to plummen For This Useful Post:
gregzoll (10-05-2012)
Old 10-04-2012, 06:09 PM   #5
Rewards Points: 582
really a hack job.... very very very very very and one more very poor job....
Old 10-04-2012, 11:58 PM   #6
Rewards Points: 616
yep something seriously wrong there....
carmon is offline   Reply With Quote
Old 10-05-2012, 07:56 AM   #7
Rewards Points: 6,652
Home owner hack job is my guess.
Old 10-18-2012, 02:48 PM   #8
Rewards Points: 53
Thanks.
The previous owner's husband, who passed in 2000, seems to have fancied himself a DIYer.
That shaft just ends as an opening above our boiler/furnace (which has a separate and actual vent stack). One of those two cables just stops halfway down - with exposed wires and all. I need to figure out what the purpose of this odd opening was in the first place.
If I can see loose fill insulation from the attic, then I've presumably got a pretty major air leak here.
Old 10-19-2012, 05:43 PM   #9
Rewards Points: 53
Below that mess, there's this shaft:
IMG_3213 by DC Orbiters, on Flickr
Above that mess, that metal conduit just ends:
IMG_3211 by DC Orbiters, on Flickr
So, apparently, this is simply a pointless shaft that houses a pointless length of old rigid heating conduit which has a pointless hole cut into it which lines up with a pointless space covered by a pointless vent cover. The shaft is also home to a pointless water pipe that connects to nothing on either end, one live cable, and one dead cable.
But why, previous owner who is now deceased, why?
Tags
intake , oil furnace , ventalation
Fresh air intake vent Topher23 HVAC 7 02-26-2008 08:12 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
Styrofoam vs. Plastic vent channels dpreznik Roofing/Siding 14 05-10-2007 02:58 PM
