Should I Add A Heat Register To This Room? PIC* - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 03:22 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Should I add a heat register to this room? PIC*
Ok, here is my family room. The problem is, its always a little to cold down here. The room does not have adequate heat register I don't think. It has two on one wall that you can see in the second pic (the other is on the other side of the couch). The branch runs in a soffit across the room. It would be pretty easy for me to soffit down right next to the soffit that you can which contains the support pole and add a register. The uncertainties I have are as follows: 1. The register would have to stop above the freezewall and be about 4' off the floor so I don't know how much it will help. 2. I don't know if tapping off of my heating system will effect the heat going to other rooms. 3. Any other questions I might be missing... Can anyone shed some light...
The heat is forced hot air by oil.
J187 is offline   Reply With Quote
Old 12-26-2008, 10:21 AM   #2
J187's Avatar
Rewards Points: 508
Nobody has any suggestions?
Old 12-26-2008, 10:54 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
It is very difficult to get a comfortable setup for one room only especially if it is in a basement. I would recommend a electric baseboard heater. If you want good control of it buy a good 240 volt type and have a thermostat for it installed on the wall. The advantages are that you have control of the room temp/comfort and you can turn it up only when you need it( saves $$). I balance ductwork in large houses and unless you have a zoning system with dampers/tstat for that room you won't get what you want. Zoning systems are very expensive/complicated and not suited for 1 room only unless you want to custom design it/have lots of $$ to spend.
Old 12-27-2008, 01:54 PM   #4
J187's Avatar
Rewards Points: 508
Yeah. I see what you are saying I thought of electric baseboard or even an electric fireplace. I just didn't know if maybe the registers were too few for the room and if it would hurt to try to just add another... Thanks for the suggestions.
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Do I need to heat the mud room if I'm using a wood stove? ezrasuncle HVAC 9 12-10-2008 06:54 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Molding over heat register patrickosu Remodeling 4 02-16-2008 12:07 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
