Old 06-04-2012, 03:32 PM   #1
Should the evaporator coil be installed 6" above the furnace?
I'm looking for a dealer to install a AC. Had talked with several. One of them told me that the evaporator coil should be installed 6" above the furnace opening, but the cased coil doesn't, so don't use the cased coil. Is this true?
lameon is offline   Reply With Quote
Old 06-04-2012, 03:49 PM   #2
I'm Your Huckleberry
Not exactly sure of what you mean. Is this a vertical upflow system? Any pics you can provide?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-04-2012, 03:55 PM   #3
I don't have any pics, since it has not been installed yet.
I think my furnace is a upflow system. Heated air comes up direct above the furnace and the returning air comes in from the side of the bottom of the furnace.
As I know, a evaporator coil would be installed in side the duct just above the furnace. Someone said that there should be a 6" clearance, is this true?
Old 06-04-2012, 04:02 PM   #4
If it's an upflow you don't have a choice in the matter. The evaporator coil will sit butted up directly on top of the furnace cabinet and that is factory install, no spacing required. And I'm not certain what you mean by the coil sitting inside of the duct other than sometimes the case/cabinet of a box coil is removed and the actual supply air plenum is put over the entire thing, with ducts running from it. It still sits at the exact same heigth with or without the case, directly sitting on top of the furnace.
Not the best way, cased coil is factory, but it has been done and it will work.
Thanks.
Old 06-04-2012, 04:07 PM   #5
Btw, people tend to remove the casing of the coil when they don't have the correct size dimensions to match up to the furnace. Three sides, the left, right and the back casing of an upflow evaporator coil should be FLUSH to the same three sides of the furnace. The front side will sit back on top of the furnace, behind the flue pipe.
Your furnace has a lip on the top so the evaporator fits perfectly onto it.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
lameon (06-04-2012)
Old 06-04-2012, 04:08 PM   #6
REP
It is reccomended that when installing an evap on an oil furnace that it be at least 5" above the furnace.
I have never seen any simuliar reccomendation for gas or elec furnaces.
REP is offline   Reply With Quote
The Following 2 Users Say Thank You to REP For This Useful Post:
Doc Holliday (06-04-2012), lameon (06-04-2012)
Old 06-04-2012, 04:27 PM   #7
Thanks Doc! When I say duct, I mean the plenum. In this case, they call it uncased coil.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace Interlocking for HRV mk5tdi HVAC 5 03-10-2012 02:27 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
armstrong furnace problems snipe609 HVAC 1 01-29-2011 10:25 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
