Which Should Be The Correct Wiring Thermostat Diagram For This Heatpum - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2016, 08:20 PM   #1
Rewards Points: 138
Which should be the correct wiring thermostat diagram for this heatpum
it is a goodman model # (GPH1336H41)
i think the correct diagram is on page 22 noted: Wiring Diagram — GPH1324-42H41C* / GPH1348HA1D*
can someone please confirm? if it is, why is that extra "C" and asterisk at the end?
this is the link:
http://www.goodmanmfg.com/Portals/0/.../SS-GPH13H.pdf
form8829 is offline   Reply With Quote
Old 02-09-2016, 09:07 PM   #2
Rewards Points: 46
Page 2 describes this. Digit 11 is the major revision number, 12 is the minor revision. * means it's irrelevant.
Cheers!
supers05 is offline   Reply With Quote
Old 02-09-2016, 10:04 PM   #3
DOUG1111's Avatar
Rewards Points: 464
i think the correct diagram is on page 22 noted: Wiring Diagram GPH1324-42H41C* / GPH1348HA1D*
this is the link:
I do not fully understand your question. Tips - "C" --T/S wire is common 24 volts ac - simular, kind of like a negative post(-) on a 12 volt car battery. Your "C" wire starts or you could say ends @ the transformer(TR) "C" wire goes to one side of your switching devices. Some T/S needs a "C" -some don't. Might be EZ for you if you look @ the wiring pic that came with the T/S
DOUG1111 is offline   Reply With Quote
Old 02-10-2016, 03:29 AM   #4
An old Tradesmen
Rewards Points: 6,906
He is asking about the nomenclature designations.
OP, Diagram on page 22 would be the correct diagram.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
form8829 (02-10-2016), supers05 (02-10-2016)
Is it normal to have the furnace control panel wiring, not match the wiring diagram cjbeck71081 HVAC 6 07-18-2012 11:19 AM
Thermostat Wiring justin_bliar Electrical 4 01-23-2012 08:06 AM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 08:18 PM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 05:54 AM
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 04:35 PM
