Shortening Supply Trunk? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 11:36 PM   #46
An old Tradesmen
Rewards Points: 6,592
Originally Posted by shuship View Post
is it possible to knock out one of the "Vs" on the truss, then reinforce with 2-3 vertical runs in order to run the supply?
Nope.
They are engineered trusses. They are designed to bear the load as they are built. The webs spread the weight over a large area.
A couple 2x4's in a vertical position won't spread the weight, and will cause stress failure.
You alter them. And they will NOT have the same load bearing strength.
Old 12-02-2008, 11:40 PM   #47
shuship's Avatar
thank you for the reply beenthere. I will move on to other means of tackling this issue.
shuship is offline   Reply With Quote
Supply and Return Issue billybob45 HVAC 4 07-31-2008 10:44 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 01:22 AM
Galvenized supply to PEX, How to make connection? twilightcall Plumbing 4 07-28-2008 10:28 PM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 12:26 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
