Shortening Supply Trunk? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 09:17 PM   #31
BTW you called pipefitter696 a roofer.
He is not.
He belongs to the Elite 636. He has a PHD in industrial HVAC service technology.
hvaclover is offline   Reply With Quote
Old 12-02-2008, 09:31 PM   #32
Rewards Points: 292
Originally Posted by shuship View Post
Not even close burr (is that some reference to your (lack of) sharpness?
Actually, that should be: (is that some reference to your (lack of)) sharpness? Or, alternately, you could have written: [is that some reference to your (lack of)] sharpness?
V
veesubotee is offline   Reply With Quote
Old 12-02-2008, 09:40 PM   #33
Jeeze. Must be a DEEP hole.
Old 12-02-2008, 09:53 PM   #34
An old Tradesmen
Rewards Points: 6,130
Doesn't look like your trusses are dep enough to shorten the trunk line by running the supplies in webs.
Old 12-02-2008, 10:07 PM   #35
shuship's Avatar
is it possible to knock out one of the "Vs" on the truss, then reinforce with 2-3 vertical runs in order to run the supply?
shuship is offline   Reply With Quote
Old 12-02-2008, 10:08 PM   #36
we now know he def. isnt an engineer!
burr is offline   Reply With Quote
Old 12-02-2008, 10:09 PM   #37
Been you got a PM
Old 12-02-2008, 10:15 PM   #38
shuship's Avatar
He is not.
Thought this was over, guess not. He referred to himself as a roofer, then you answered and asked him how it was up there. Check w/post #5, then read on.
Can we move on puh-lease??!!!!
Old 12-02-2008, 10:22 PM   #39
THERE"S No problem. He said he was ON a roof where the HVAC equip is.
I just figured he deserved that clarification, that's all.
Old 12-02-2008, 10:29 PM   #40
shuship's Avatar
Get over yourself will ya....holy smokes.
He did NOT clarify he was there working on the HVAC equipment, and I'm quite sure he is more than capable (having a Phd an all) of answering for himself. I guess I just figured with him "being on a roof for 10 hrs." he wasn't a grocery clerk or barber (no offense to either as I've been both). Thanks again....for the clarification....
Old 12-02-2008, 10:35 PM   #41
Uncalled for, friend.
I am going to be surprised if you get any input
at all unless it's from a non-pro.
Old 12-02-2008, 10:38 PM   #42
shuship's Avatar
I am going to be surprised if you get any input at all unless it's from a non-pro.
What?! You can't be serious....after all we've been thru these past few hours? That's it? You're leaving? Just like that? Uncalled for? C'mon.....
Old 12-02-2008, 10:40 PM   #43
shuship's Avatar
someone had answered a question (beenthere I believe was his handle). I quipped back in hopes that would open a different lane.
I had moved well on earlier when you asked I repost....it was you and Mr. Burr who then re-upped the taunting.
Old 12-02-2008, 10:47 PM   #44
It HAS moved on. It's just YOU.
Nobody wants to help out a smart aleck, sorry. You did it it to your self.
Old 12-02-2008, 10:56 PM   #45
Thread is closed
Supply and Return Issue billybob45 HVAC 4 07-31-2008 10:44 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 01:22 AM
Galvenized supply to PEX, How to make connection? twilightcall Plumbing 4 07-28-2008 10:28 PM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 12:26 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
