Short Cycling Furnace ? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 06:56 AM   #1
short cycling furnace ?
Hey guys, I have a goodman gmp-100-4 80,000 Btu output furnace. My question is what is considered short cycling? I have timed the on and off times and came up with an average of 7 minutes on and 10 minutes off.
Bob M is offline   Reply With Quote
Old 02-15-2012, 07:50 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 382
sounds short but it depends where you live, how cold it is, how well house is insulated, possible drafts by tstat etc. I would expect 15 mins off. some elec tstats have a cycles per hour adj in the menu. cheap ones don't.
Old 02-15-2012, 04:10 PM   #3
HVAC Tech/ Browns Fan
You have good window's?
Tator1076 is offline   Reply With Quote
Old 02-16-2012, 11:30 AM   #4
yuri, i don't have an expensive tstat just a basic digital one. the insulation is poor. only r-19 in the attic floor.tator, i have 2: bay windows about 4'x7' in the room with the tstat. they are roughly 15 years old. they are double pane glass but they do get pretty cold. thanks guys.
Old 02-16-2012, 11:47 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 382
then your cycles are normal. even a more expensive elec type will give U those cycles but you can try one and tweak it a bit to possibly make them longer, will feel chilly though. won't decrease your gas bill either. need better insulation and door stripping etc.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Short Cycling Boiler? matt151617 HVAC 40 01-11-2012 05:24 PM
Honeywell VisionPro Short Cycling? kcrossley2 HVAC 33 01-19-2011 03:02 PM
Proportional cycling for gas furnace Ultrarunner2017 HVAC 7 11-11-2008 07:56 AM
furnace cycling / shut down Snailspace HVAC 12 02-04-2008 09:08 PM
